Stub Axle
9 replies to this topic
#1 dob
dob
  • 71 posts
Posted 25 July 2010 - 04:47 PM
hi guys n gals,the stub axle thread is damaged on the end where the hub nut goes on and i need to the stub axle,can this part be removed from the radius arm?..thanks dob
#2 dob
dob
  • 71 posts
Posted 25 July 2010 - 06:39 PM
i have also found the rear shock didn't have a retaining nut on as the thread on the suspension mount is also damaged,can this also be replaced?..thanks dob
#3 dob
dob
  • 71 posts
Posted 25 July 2010 - 07:15 PM
if i need a new axle pin and shock mount can anyone tell me if there's any particular type i need for a 93 mini cooper?..thanks dob
#4 Azbornmini
Azbornmini
  • 93 posts
  • Local Club: Classic Minis of Arizona
Posted 26 July 2010 - 12:54 AM
I believe you can change out the stub axle on you radius arm. It has to be pressed in.
http://www.minispare...ty=pb&pid=33418
#5 GraemeC
GraemeC
  • 7,440 posts
Posted 26 July 2010 - 07:31 AM
It will be cheaper and much, much easier to simply fit a recon radius arm that will come with a good pin already installed.
#6 dob
dob
  • 71 posts
Posted 26 July 2010 - 07:09 PM
where is the best place to buy a reconditioned radius arm and are they easy to remove and fit?..thanks dob
#7 Azbornmini
Azbornmini
  • 93 posts
Posted 26 July 2010 - 09:22 PM
http://www.minisport...fo_XLRA28L.html
#8 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 26 July 2010 - 09:24 PM
I've changed a stub axle with a blow torch and a copper hammer. So its do-able at home.
#9 GraemeC
GraemeC
  • 7,440 posts
Posted 27 July 2010 - 06:35 AM
Cheaper at MiniSpares:
http://www.minispare...=...7305&title=
For that price it is not worth the hassle of trying to get the stub axle out (which will cost you more anyway). Arms are not difficult to fit an if you needed to get the axle pressed out you would have to take the arm off the car anyway.
Harber's way might work 'on car' but I would expect it to be a 50/50 chance of success. They are a very good interference fit and usuallt require a 10t press to remove - admittedly some are tighter than other.
#10 MRA
MRA
  • 7,607 posts
Posted 28 July 2010 - 01:01 AM
You may get charged for a new or relacement pin (stub axle) as these are rarely replaced on exchange..... especially for that price.....
