Help With Block Casting Number
8 replies to this topic
#1 sx_turbo
sx_turbo
  • 214 posts
Posted 26 July 2010 - 02:12 PM
Model: a-series 998
Year:n/a
Description of problem (please be as in depth as possible): recently stripping down an engine that i picked up, and there are no engine number plates on it.
i have managed to find out that it has an pre a+ crank, and an a+ unleaded head.
the casting number on the back of the block is wfm1028, but i cant seem to locate this casting number, i need to get parts for it, any help would be appreciated :D
i just want to know if the block is pre a+ series, and roughly what age the block is.
it also has a no.3 cam if thats any help, what is a number 3 cam any body know?
Edited by sx_turbo, 26 July 2010 - 02:23 PM.
#2 sx_turbo
sx_turbo
  • 214 posts
Posted 26 July 2010 - 09:29 PM
bump
#3 Asphalt
Asphalt
  • 2,173 posts
Posted 26 July 2010 - 10:39 PM
Could it possibly be WFM1026? As that would be a A+ smalbore (998) block :D
#4 sx_turbo
sx_turbo
  • 214 posts
Posted 27 July 2010 - 09:44 AM
i will double check but i pretty certain it's not,
thankyou for your help
#5 sx_turbo
sx_turbo
  • 214 posts
Posted 27 July 2010 - 08:58 PM
had a look this evening and the block definately says wfm1028.
i have an a+ block sitting around that is no good, and that says wfm1026, would i be right in assuming that wfm 1028 theoretically should be a later block?
#6 MRA
MRA
  • 7,607 posts
Posted 27 July 2010 - 11:52 PM
1024 is 1275 A+
1026 is 998 A+
1028 is..........
Are you sure it is a transverse engine block ?
#7 sx_turbo
sx_turbo
  • 214 posts
Posted 28 July 2010 - 03:32 PM
yeah it's defo a tranvsverse block,
well it looks almost identical to the a+ i took apart and swapped all the stuff over to.
i ordered the bearings for it today, and the company i ordered the bearings with said it's got a-series bearings.
i'll have to get a pic of the casting number
#8 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 28 July 2010 - 03:34 PM
to find out if its a-series or A+
take a look at the dizzy mounting hole, they are different.
also note the position of the alternator mounting bracket, again they are different.
Mounting bracket closer to middle of engine is A-series
Mounting bracket closer to R/H (radiator end) is A+
Jordie
#9 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 28 July 2010 - 03:36 PM
Yup, pic would be the way forward, the more photos of different parts of the block the more useful they will be!
