Adjustable Bottom Arms Conversion
3 replies to this topic
#1 timmins
timmins
  • 109 posts
  • Local Club: Mid Atlantic Minis
Posted 27 July 2010 - 01:08 PM
I'm going to fit the non-spherical jointed adjustable bottom arms to my 77 Clubman, and I found a local company who think they can set it all up.
Can anyone tell me if I'm missing anything from the Minispares order below, or if I should be replacing anything else while I'm at it? Is it really necessary to get the longer track rod ends if it's going to have -1 degree camber? I's appreciate someone looking over it because I'm in the US, so it's a real pain when I forget to include things in the order!
1 x C-AJJ3360 - LOWER ARMS ON CAR ADJUSTABLE
1 x C-STR632 - LOWER ARM BUSH SET FOR MODIFIED GEOMETRY ROAD
2 x C-AJJ1572 - TRACK ROD END LONGER TYPE
2 x 2A4362MS - LOWER ARM PIN
Thanks,
Tim
#2 kalkat
kalkat
  • 95 posts
Posted 27 July 2010 - 02:22 PM
You should add adjustable tie rods ..... and the cost of having it set up too
#3 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,231 posts
  • Name: Simon Jackson
Posted 27 July 2010 - 02:35 PM
As above, adjustable tie rods, 21A1091, bushes, C-STR627 and to make life easy some new bolts, 53K1031
#4 timmins
timmins
  • 109 posts
Posted 27 July 2010 - 02:56 PM
I'm a fool, I forgot to mention it already has adjustably tie rods fitted.
Thanks for the responses!
