Radius Arm Removal
8 replies to this topic
#1 dob
dob
  • 71 posts
Posted 28 July 2010 - 05:54 AM
as it looks like i'll have to have a go at removing the radius arm from my 93 cooper,is this a difficult job to do?..thanks again dob
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 28 July 2010 - 06:04 AM
Not really although like anything mini it depends on how rusted / seized nuts and bolts are
remove road wheel
detach shock absorber
detatch handbrake cable at the wheel end and off the quandrant on the radius arm.
undo flexi brake pipe where it attaches to top of radius arm
undo outer bracket (4 bolts , 2 above and below radius arm, 2 underneath (no need undo large nut next to grease nipple "YET" )
Then inside subframe you will find the other nut for the pivot shaft, undo
should now be able to pull radius arm off the car.
it will come off like this complete with brake assy and hub
think thats everything, I find a long reach 1/2" or 13mm socket pretty good for getting at the bolts above and below the radius arm
#3 jayare
jayare
  • 2,093 posts
Posted 28 July 2010 - 03:02 PM
You'll also need to move the fuel tank to do the N/S one - make sure you run the fuel down as much as you can before starting.
The main issue you are likely to encounter is seized & rusted fasteners,
JR
#4 dob
dob
  • 71 posts
remove road wheel
thanks for the info,do i clamp the flexi hose somewhere under the car if i'm removing the arm?..dob
#5 dob
dob
  • 71 posts
Posted 28 July 2010 - 03:23 PM
remove road wheel
i forgot to ask,is it better to buy a recon arm or just replace the stub axle?thanks again fellas...dob
#6 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 28 July 2010 - 03:29 PM
recon arm would be easier.
Stub axle will require a press and maybe alot of heat to fit.
arm is a direct swap once you have swapped the brakes and hub over.
Jordie
#7 dob
dob
  • 71 posts
Posted 28 July 2010 - 03:43 PM
Jordie
thanks jordie,where do i clamp the flexi hose when i remove the arm,is there somewhere on the subframe mate?
#8 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 28 July 2010 - 03:46 PM
when you undo the flexi from the metal pipe on the arm, you can clamp the flexi.
#9 dob
dob
  • 71 posts
Posted 28 July 2010 - 03:48 PM
nice one thanks mate..dob
