Hi,
I've just put a MG Metro 1275 into my mini but it wont start. The electric ignition system its self came with the engine all I have done is use the coil from my 998. It does produce a spark but it doesnt look strong enough for the engine to get going. I think this is because the 998 coil is a ballast resistor type and I've heard that a 1275 with electronic ignition needs a particular coil type. Does anyone know what type it is? And where I could find one?
Mg Metro Ignition Coil
Bubba1
, Jul 29 2010 10:19 PM
6 replies to this topic
Posted 29 July 2010 - 10:19 PM
Posted 30 July 2010 - 07:29 AM
Coil you need is GCL143 - minispares or more reasonably your local partco flog them....
Posted 30 July 2010 - 12:26 PM
Thanks for the reply!
I've just done some poking about ont t'interweb and I've been reading various topics on people with similar problems and some one recommended the DLB198. Which would be best?
Posted 30 July 2010 - 04:09 PM
think they're the same thing depending on whether unipart or lucas part reference - either will be ok!!!
Posted 30 July 2010 - 05:16 PM
I have also just installed an MG metro engine into my mini and i am running my points ignition coil with electronic ignition and it runs perfectly. I have however had 2 coils pack up on me within around 6 months so whether this is due to engine vibration or because its not the electronic type then i'm not sure. I have though just picked up a metro electronic ignition coil which says 'only to be used with contactless breakers' or similar.
Posted 30 July 2010 - 08:11 PM
Dont forget you need to wire in a switched 12v feed to your new electronic coil. Take it from the top fuse of your fusebox.
Posted 03 August 2010 - 12:49 PM
So i just need to run a wire from the top of the fuse box to the coil?
