ok looking to get an engine.
the code is 12hd24 131763
unsure what engine this is.
been looking on the minimania site
http://www.minimania...ata_UPDATED.htm
but this don;t seem to be there,
any help be great thank steve
Help Identifing Engine Code.
booton
, Jul 30 2010 05:35 PM
4 replies to this topic
Posted 30 July 2010 - 05:35 PM
Posted 30 July 2010 - 06:14 PM
Its an 1988 mg metro engine with a 3.44-1 final drive on a standard ratio box. As per guessworks web site. Engine number page, Take a look. You did not supply the suffix code, so this is as much info as i could find.
Here you go
http://www.guess-wor...ical/engine.htm
But i did the hard work for you
Source Vehicle : MG Metro
Engine type & CC : A+ 1275 cc Transverse mounted
Fueling :
Engine features : Pre-engaged starter
1985 Requirements
1988 Model year
Breakerless (electronic) ignition
Gearbox features : Std. Ratio Rod Change gearbox with Pot Joints
3.4:1 Final Drive
Fueling :
1985 Requirements
1988 Model year
3.4:1 Final Drive
Posted 30 July 2010 - 06:26 PM
it tha great thanks its just the block, tho not the gear box,
do u think there be any problems fitting a mini gear box. to this engine
Posted 30 July 2010 - 06:36 PM
No problems, Will it be the original box from the car? If not your speedo might read wrong unless you use the same final drive ratio.
