Today after I overhaulled my car and did all the "Weekend" maintanance bits. After a short drive around town, Ive noticed a Knocking sound comming from the front left of the car when I go over bumps.
I thaught it may have been my wheel nuts not tight, but I got out and checked them. They were fine.
Theres no play in the wheel (Balljoints OR wheel bearing).
Any ideas?
<|Ben|>
knocking noise
binge
, Nov 27 2005 10:12 PM
5 replies to this topic
Posted 27 November 2005 - 10:12 PM
Posted 27 November 2005 - 10:28 PM
Did you torque up everything to the correct setting? Did you undo the track rod ends?
Posted 27 November 2005 - 10:40 PM
nope, Not undone trackrod ends.Did you torque up everything to the correct setting? Did you undo the track rod ends?
I dont have a torque wrench, So I just tighten it until I feel its tight enough. Ive sheered a few things off the the past. :nugget:
its just a worrying noise. :tongue:
Posted 27 November 2005 - 10:44 PM
Dead damper mounting bushes? Grab the damper and check if you can rattle it around.
Posted 27 November 2005 - 11:01 PM
That being? :tongue:Dead damper mounting bushes? Grab the damper and check if you can rattle it around.
The shock / Suspension looking thing.
Or
The trumpet / cone looking thing?
Cheers.
Posted 27 November 2005 - 11:04 PM
the shock absorber or "damper"
