2nd Battery
Posted 09 August 2010 - 09:22 PM
any help appreciated
sean
Posted 09 August 2010 - 09:43 PM
Let me just find a link to one.. I have one on the garage..
Edit: I can't find the link, but basically you put one 12v feed into this little box, and two out to each battery then it decideds which one to charge by comparing the two voltages..
I can't find it on maplin where I got mine from..
Edited by rusty789, 09 August 2010 - 09:46 PM.
Posted 09 August 2010 - 10:39 PM
I personally don`t think its worth the effort.
Posted 09 August 2010 - 11:41 PM
Posted 10 August 2010 - 06:48 AM
Posted 10 August 2010 - 08:36 AM
The benefit of this is:-
1, it won't drag the alternator on starting
2, the second battery charges when the ignition is one AND the headunit is on.
3, You can play music with engine off for as long as you like and will not affect main starter battery, no need to worry about flattened battery.
...alternatively, if you're going for a modest install (<500wRMS) then you can use a split diode (i have one which is not being used). This is a Lucas oil-cooled, twin diode. The centre tag is alternator in & 2 outputs, one for each battery. It's rated around 45A (i don't know if that's total or per diode) i couldn't find much info on it. Ideally mounted under the bonnet near the alternator with access to air-flow. If you're interested you can have for £20 via paypal (PM me) i only have one of these.
Posted 10 August 2010 - 12:54 PM
just out of curiosity where would be the best place to put the 2nd battery?
Posted 10 August 2010 - 02:17 PM
cheers everyone you have been very helpful.
i've removed the heater matrix and put a Red-top there & 4 Yellow tops behind the driver/passenger seats (not recommended for an everyday car!)
depends what you're installing. the easiest place is to put the second battery on top of the existing battery, using a DIY cradle. however, if you're planning on putting ICE in there, not good.
Instead of a large second battery, you could go for a bank of 12v alarm batteries and have these wired in parallel. the good thing about this, is you could have these fitted almost anywhere. ie. under the rear seats, in the side pockets. I would put 4 in each side pocket this should give roughly the same Ah as a large battery (8x 8Ah = 64Ah)
Posted 11 August 2010 - 12:27 AM
i only want the second battery anyway because i want to stick quite a few bits of electrical equipment in the car and dont want it diein on me lol. not quite sure what as yet mind but i keep having crazy ideas so always good to be prepared.
Posted 11 August 2010 - 08:50 AM
Posted 11 August 2010 - 11:37 PM
Posted 12 August 2010 - 10:04 AM
Posted 12 August 2010 - 10:17 AM
Posted 13 August 2010 - 08:15 AM
wouldn't it be easier just to fit a bigger/better battery?
the benefit of a second battery with controlled charge/isolation is you can use the second battery for audio, fridge, alarm etc while the engine is off, then not having to worry about returning to the car with a flat starter battery.
Also useful if for some reason you do have a flat starter battery, flick the relay on and you've got a built in booster pack!
