Tuning 998 On A Tight Budget
15 replies to this topic
#1 Minii_Matt
Minii_Matt
  • 55 posts
Posted 10 August 2010 - 11:09 AM
Hi, I currently have a 1985 Mini City E with stage 1 kit fitted and am now feeling the hunger for more power. Unfortunately, I am on a very tight budget and do not have a lot of money to play with. I've looked into getting a new cylinder head, but these seem expensive and I would have to save to afford one. 1.5:1 roller tip rockers have also taken my fancy claiming to up power, but I have seen mixed reviews on these, especially when fitted to 998 engines. Also, would 1.5:1 be the correct ratio to go for?
Any advice on where I should go from here would be greatly appreciated.
Many thanks in advance,
Matt
#2 coopermpi
coopermpi
  • 661 posts
  • Local Club: not yet
Posted 10 August 2010 - 11:24 AM
im in the same situation and ive gone for a 12G295 head (fleabay jobby) a nikki carb (or similar, depends what you want) you've got the exhaust from stage 1. As far i was aware the standard rockers were best for the 998, and you can chage the cam if you want to take the engine out.
Id like to hear anymore ideas for me too.
#3 Minii_Matt
Minii_Matt
  • 55 posts
Posted 10 August 2010 - 11:31 AM
Thanks for the reply, did the 12G295 head make a noticeable difference? Also, did it need reconditioning, as that is what seems to cost the money? I have heard a lot of people recommend a new cam, but am not keen on taking the engine out as I need the car as my daily drive!
#4 Big_Adam
Big_Adam
  • 7,435 posts
Posted 10 August 2010 - 11:40 AM
Ahem
*clears throat*
DAVID VIZARD - HOW TO TUNE THE A-SERIES ENGINE.
Keep it by the bog and read it.
#5 coopermpi
coopermpi
  • 661 posts
Posted 10 August 2010 - 12:41 PM
Thats a question i cant answer as mines a project and im still doing the bodywork before i start on the engine. Ive just been collecting bits as and when i find them!
The head i got just needs skimming and maybe new seats to run on unleaded. I think it can be quite expensive to get done but i bet its not as much as a new head, and from what i researched this was the sought after head for the 998.
#6 Wil_h
Wil_h
  • 3,244 posts
Posted 10 August 2010 - 03:04 PM
A 295 head is the way to go. Then a camshaft would be next. I got an MG cam foe £15 and that combined with the head gave 55bhp.
You will need new cam followers if fittting a cam, but they are cheap.
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 10 August 2010 - 03:36 PM
A 12 G 940 head is MUCH BETTER - and much cheaper than the 295. And don't waste money on daft high lift rockers. Chase up an MG Metro cam if you can - and yes - it can easily be fitted to a 998 engine in the car.
Edited by bmcecosse, 10 August 2010 - 03:37 PM.
#8 coopermpi
coopermpi
  • 661 posts
Posted 10 August 2010 - 03:45 PM
i was under the impression the only way to fit a cam with it in the car is to cut a hole in the inner wing and slide it in, other than that i thought it was an engine out job.
#9 bmcecosse
bmcecosse
  • 9,699 posts
Posted 10 August 2010 - 03:47 PM
Yes of course - takes about 1 minute to cut the hole! Much easier than taking the engine out........ If really bothered - can make it a replaceable 'patch' held on with a few self tappers.
#10 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 10 August 2010 - 03:50 PM
How do you deal with the cam followers? if you just slide the cam out, providing it doesnt get caught on a follower its self?
Its ok just realised you are dealing with a 998!! tappet chest covers :))
Edited by nomininolife, 10 August 2010 - 03:52 PM.
#11 bmcecosse
bmcecosse
  • 9,699 posts
Posted 10 August 2010 - 03:56 PM
That's the BIG advantage of the 848/997/998/1098 (and Cooper S) engines!
#12 dave-r5
dave-r5
  • 317 posts
Posted 10 August 2010 - 04:03 PM
i know what the next mod im doing is
#13 Spitz
Spitz
  • 1,716 posts
Posted 10 August 2010 - 04:10 PM
I could see using roller rockers....if they are of the 1.3 variety however.
Keep in mind a 12g295 Cooper head would need to be milled/shaved to reach the proper chamber capacity. You can't just take a 295 and plonk it on...well you could, but I imagine your compression would be like 7.1 or so
#14 Wil_h
Wil_h
  • 3,244 posts
Posted 10 August 2010 - 06:03 PM
Actually, just slapped straight on a 998 with flat tops you gey around 9.3:1 CR, great for a turbo, ok for NA, but better to skim it and get 10:1.
#15 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 10 August 2010 - 06:18 PM
David Visard Book be best thing to buy :P
Im tuning my 988 having
Port & Polish
Cam But not sure what yet
12g940 head
Rebuilt carb (already) but with a Sock filter & Trumpet
3 - 2 - 1 Mani Flow down pipe with middle box and RC40 center exit
Inlet manifold
haha there's more but im undesided on what else
im debating with myself on a Turbo atm!
