The mirrors are the first job and are ABS plastic. I've rubbed them down with 600 grade paper and primed them with plastic filler primer, i've given them a good 3-4 thin coats with 10-15mins between each coat and they're now drying off overnight so I can spray them tomorrow.
Because I was spraying outside a couple tiny bits of dust/grit have got stuck in the primer. So I need to give them a quick rub down tomorrow before I spray them - What grade paper should I use for this? Then i'll give them a quick wipe with panel wipe and get them sprayed.
They're being sprayed gloss black, then lacquered to hopefully give them a really nice shine. I've never used lacquer properly before, only on my bike once where finish wasn't important. So i'm planning on spraying the black on in the same way as the primer - Thin coats built up with 10-15mins drying time between coats until i'm happy with the coverage/finish. I've searched on the forum and can't work out whether I should spray the lacquer on shortly after the paint - i.e. 15mins to allow the paint to flash off and become touch dry or if I should leave them overnight again and lacquer them the next day? Different people say different things - So whats best?
One last thing is, if I end up getting any dust/grit in the black or lacquer - Whats the process for removing it? Should I allow to dry fully and then rub down and respray again?
Edited by mike., 10 August 2010 - 10:00 PM.
