Is The Brake Servo Not Working A Mot Fail?
7 replies to this topic
#1 scathontiphat
scathontiphat
  • 33 posts
  • Local Club: S.U.N.M.C.
Posted 11 August 2010 - 08:58 AM
Model:Rover Mini Sidewalk
Year:1995
Pretty sure my brake servo is kaput. Never thought to replace it though, as it does not bother me not having power assist in braking. But it's MOT time, and I'm wondering if I need to replace this before I go get it inspected?
thanks!
#2 Pooky
Pooky
  • 5,691 posts
Posted 11 August 2010 - 09:40 AM
Let me google that for you!
UK MOT info, 'Correct operation of the servo assistance system' is checked.
#3 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 11 August 2010 - 09:47 AM
Yes its a fail its inefficient braking and something else
i do believe rover 100 & metro had same servo but im un sure to be honest havent seen a mini one up close
#4 valve bounce
valve bounce
  • 694 posts
Posted 11 August 2010 - 12:56 PM
just remove the servo, it its not there it cant be tested and there not necassary anyhow
#5 icklemini
icklemini
  • 2,982 posts
Posted 11 August 2010 - 01:34 PM
And dont forget to tell your insurance!
#6 cooperrodeo
cooperrodeo
  • 379 posts
Posted 11 August 2010 - 03:48 PM
er there is an MOT clause which says something like if car was originally fitted with one then it's a failure if it's not there or disconnected. If it was not originally fitted with one then if one is there but disconnected, then that is no reason for failure.
How do I know? Well my machine passed all the usual brake tests but failed because my servo was not in circuit and should have been. The MOT man rang the MOT people to check. There was nothing wrong with the brakes but it failed on a mere technicality. If it had not been present, the MOT man admitted it would have passed because he did not know that one was originally fitted.
#7 scathontiphat
scathontiphat
  • 33 posts
Posted 11 August 2010 - 05:30 PM
Bummer i can't just take it out. How can i determine whether it's the servo or the hose that's shot? I pump up the brakes and then turn on the engine and the pedal doesn't move. Brakes seem to work fine though, no problems braking, it's just a stiff pedal. I don't see any signs of brake fluid leaking anywhere in the area. Around the vacuum line banjo bolt going to the manifold, there does seem to be a bit of greenish corrosion. Although the engine seems to run fine.
Also, if needed, anybody know where to get a replacement hose? I see one at minisport, but it's £30!! seems a bit steep for some hose, fittings, and whatever that valve/filter thing is in the middle.
thanks!
Edited by scathontiphat, 11 August 2010 - 05:31 PM.
#8 mknige
mknige
    Just On Tickover
  • 5 posts
Posted 23 August 2010 - 02:09 PM
thanks!
I've got one of those hoses if you still need it?
