1293 Engine - Hydrocarbon Problems
Posted 12 August 2010 - 08:03 PM
1275 GT
Year:
1977
Just entered my mini in for its MOT. It failed its emmisions on the HC (Hydrocarbon Levels). The max being 1200 ppm and my best result being 1800 ppm. I had a mobile engine tuning guy today to check everything over. He believes the carb is fine and has correct jets and needles. He thinks it must be something inside the engine.
Any non-standard parts that might be involved with the problem?
I think the issue might be linked to the Piper Cam BP285 Scatter. (The tuning guy didnt know about the exact specs of the cam) The engine also has JE race pistons, carrillo race conrods and all the usual little mods. It is a single carb but probably not the cause of the issue.
If what other people I have phoned say, the scatter cam is likely to be the cause of the issue. I am willing to remove said item and replace unless someone thinks this is not the problem. So I suppose I am asking for advice on its replacement. I want to retain the engine as a fast road engine as it is a second vehicle for fun, would just replacing it with the BP285 non scatter solve my issues? Or are there any other cams that would be recomended over this model number or make.
Many thanks
Jason
Posted 12 August 2010 - 08:17 PM
Posted 12 August 2010 - 08:21 PM
Posted 12 August 2010 - 08:31 PM
Tried the mixture screw. The guy at the MOT test did 3 different emmissions tests having fiddled with the mixture screw. The best result being the 1800 ppm.
I dont mind changing the cam shaft. If it solves the problem! I built the engine about 3 years ago... it only passed the MOT the first time because the tester fudged it. The tester this time wont! It also drinks fuel at such a rate (throwing it neat out the exhaust) it costs a fortune to run. Spend the money now and I will reduce it in running costs.
I would try the tappets, but I would have to pay £35 + Vat for every time matey comes and checks it.
Thanks for your comments.
Jason
Edited by 1275GT zeemax clubman, 12 August 2010 - 08:32 PM.
Posted 12 August 2010 - 08:34 PM
If its drinking fuel then its running too rich anyway, have you ever had it RR tuned?
Posted 13 August 2010 - 09:08 AM
What are other peoples experience with scatter cams? I am assuming that actually having checked the timing and setting it up correctly when I rebuilt the engine a year ago that it shouldnt be causing this sort of problem.
Jason
Posted 13 August 2010 - 09:19 AM
I'd suggest leaning it out while connected to the tester and remember how many turns you do it so you can reset it when you get outside.
Posted 13 August 2010 - 12:55 PM
Jason
Posted 13 August 2010 - 01:35 PM
Edited by samsernie, 13 August 2010 - 01:36 PM.
Posted 13 August 2010 - 01:46 PM
I got that from an MGB specialist as MGB's also can have that problem with SU carbs and high-lift, high overlap cams.
Apparently the Triumph Dolomite Ownersw Club issued a directive to their members to do something very similar. It's an allowable thing to do at the MoT station as nowhere is the tickover mandated at a specific figure.
Posted 13 August 2010 - 08:10 PM
Emission testing on Classic cars is not a 100% requirment and that MOT garage can adjust to suit
Posted 15 August 2010 - 12:20 PM
This weeks job is to have the cam out. It might even be faulty, miss machined etc. I assume that if I pull the engine out, flip it upside down so the cam followers dont drop having removed the push rods. I can pull the cam out and replace without spliting the engine etc? Its only recently been replaced so bearing etc will be as new. Only done 30 odd miles.
With the lightened pistons, and con rods what would be a good replacement camshaft? Maybe a bit milder than the 285?
Any help would be appreciated.
Jason
Posted 15 August 2010 - 01:10 PM
Posted 15 August 2010 - 01:54 PM
Posted 16 August 2010 - 09:12 AM
If that fails then its definitely time to change the cam.
Jason
