Gravity Or Suction Fed Spraygun
Posted 14 August 2010 - 06:38 AM
thanks
Posted 14 August 2010 - 07:06 AM
What does anyone think, I have a 2hp / 25 l compressor and a clarke suction fed gun but am having some probs maintaining constant pressure, would a gravity fed gun be better - its OK for primer but i need to get the top coat right,
thanks
I'm no expert on painting. There are plenty on here who are, and I'm sure some will reply.
The factor to consider is the air requirement of the gun you have. Switching to a gravity fed gun with the same air requirement will not show any difference.
Do you know what the capacity of your compresor is? Usually in CFM (Cubic feet per minute) on the manufacturers plate. You need to ensure that this matches or preferably exceeds the gun requirement. A bigger air tank would help but will still run out if the above criteria is not met.
The suction gun I used consumes around 9 CFM, a similar gravity fed gun around 8CFM. My compressor delivers up to 14CFM. (My old one was barely 2 with a tiny tank and would only run the gun for about 10 seconds so I know where you are on this)!
Have you got a pall who could lend you a bigger compressor for the top coat?
Hope this helps
Good luck
Steve
Edit: spelling
Edited by stevede, 14 August 2010 - 07:07 AM.
Posted 14 August 2010 - 07:08 AM
michael
Posted 15 August 2010 - 02:31 PM
Edited by JoneseyBoy, 15 August 2010 - 02:32 PM.
Posted 15 August 2010 - 02:42 PM
Posted 17 August 2010 - 05:14 AM
Posted 17 August 2010 - 07:35 PM
The trouble you will be getting a small compressor is that you want have a massive storage of air, it's not so much what gun you got but if you compressor is producing enough compressed air. I.e if your compressor runs at 8 c.f.m. but the spray gun uses 10 c.f.m. then it will struggle. I used to spray with a small compressor years ago & found that I had to do a panel & wait & so on.What does anyone think, I have a 2hp / 25 l compressor and a clarke suction fed gun but am having some probs maintaining constant pressure, would a gravity fed gun be better - its OK for primer but i need to get the top coat right,
thanks
