Small Bullet Connectors
5 replies to this topic
#1 chappy
chappy
  • 1,253 posts
Posted 14 August 2010 - 10:35 PM
Hi All,
I'm looking for some bullet connectors, but they're smaller than the usual size you can pick up from halfords and the likes.
Basically, i've just brought a Mk1/2 rear plate hanger, and the light to go with it. the connectors inside are these brass bullet sockets.
does anyone know where i can find these?
Sam
#2 rusty789
rusty789
  • 532 posts
Posted 14 August 2010 - 10:38 PM
Tried your local maplin?
As far as i'm aware there are only two common bullet sizes..
#3 danrock101
danrock101
  • 2,478 posts
Posted 14 August 2010 - 10:56 PM
I get all mine from ebay
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 14 August 2010 - 11:38 PM
You bought a Mk1/2 rear plate hanger with lamp assembly? Take a close look at what is there.
If you have what appears to be a small female socket... that IS your bullet connector. Remove it and you should find a small hole punched through the domed end. What you are supposed to do is run the stripped wire through the center, fold it back over the outside of the bullet, then plug it into the lamp's terminal.
Check out this link:
http://www.vintagemo.......ment&part=3
Look 1/3 the way down the page for item #249. That's the type of bullet I'm used to seeing on early lamp assemblies.
Item 250 is MUCH more common in either crimp or solder form.
Now look at the picture in this link:
http://www.triple-c....ges/lucas14.jpg
That's a double ground terminal. You should find a similar "coiled" female contact inside your lamp assembly. The bullet with folded over wire is inserted into that coiled contact.
#5 John Gervais
John Gervais
  • 23 posts
  • Local Club: Mini Club Copenhagen
Posted 15 August 2010 - 12:42 AM
I get my terminals and connectors at Vehicle Wiring Products (http://www.vehicle-wiring-products.eu ).
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 15 August 2010 - 01:31 PM
JEG, is that you? I don't know that I've seen you post here before! Consider this a belated welcome!
