Tyre Pressures For Falken Ze912 And Torque Settings
4 replies to this topic
#1 jacob_williams
jacob_williams
  • 37 posts
Posted 18 August 2010 - 07:52 AM
city e with 1275 metro engine
1985
hi i wondered if anyone knew the correct tyre pressure for falken 165/60 ze912's with 5 x 12 minilites taking into acount the different engine also if anyone know the right torque settings for the wheel nuts
thanks
jake
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 August 2010 - 08:21 AM
Tyre pressures can vary depending upon your driving style, use of vehicle and weight of vehicle, but you'll find the average will be about 28 psi at the front and 26 at the back... If you find the steering a little heavy, then put a couple more psi in the front and vice versa if you start experiencing undue understeer...
Torque for alloy wheels is around 40lbft as an average.
#3 jacob_williams
jacob_williams
  • 37 posts
Posted 18 August 2010 - 09:35 AM
okay thanks alot.
#4 Ethel
  • 26,074 posts
Posted 18 August 2010 - 10:38 AM
As GW says, if you think about it the tyres have much less effect on the pressure than the car they are carrying (it's the weight of the car that makes 'em flat on the bottom). Wheel nut torque could be very different depending on the style of wheel nut.
#5 jacob_williams
jacob_williams
  • 37 posts
Posted 19 August 2010 - 07:58 PM
ah okay i was asking as they are currently at around 30 psi and still appear to be bulging at the bottom and i didn't think this was correct. also what are the different styles of wheel nut? mine look roughly like this (http://www.minispare...id=33494&title=) thanks alot.
