Running On 2 Cylinders?
Posted 19 August 2010 - 07:13 PM
my 1987 mini mayfair 998 is running like a dog, basically the engine cut out the other day and when it restarted it was chugging and the engine sounded as though it was ticking, when i checked the plugs and leads only the two left hand plugs were sparking, the leads are in the right firing order, all the plugs are working as are the leads, so what could be causing the car to run on two cylinders? It was suggested by a friend that it could be the headgasket thats blown, if so what exactly am i looking for?
Posted 19 August 2010 - 08:01 PM
Posted 20 August 2010 - 11:23 AM
Posted 20 August 2010 - 11:38 AM
Posted 20 August 2010 - 11:54 AM
ok will do that tomorrow as i have day off work, would a problem with manifold gasket affect only two of the cylinders and prevent the plugs from doing there job?check the manifold gasket first, spray with carb/brake cleaner and see if the revs pick up.
Posted 20 August 2010 - 11:56 AM
Posted 20 August 2010 - 01:19 PM
yes, if it's blown then it'd suck in air after the carb and be too lean to burn.
Posted 20 August 2010 - 04:11 PM
Posted 20 August 2010 - 04:27 PM
To go back to your original post, you said that only the two plugs were sparking, but then you said that all the plugs are working. Now, which is it? If only 2 plugs are sparking, then it's either two damaged leads or a cracked distributor cap. If all plugs are sparking, then it's something else, not ignition related, such as head gasket, manifold leak or valves/compression issues.
sorry should have made my post a bit clearer, if i change the two left hand plugs with the two right hand plugs (which dont spark) the engine still runs on he two left hand cylinders likewise the leads, all the plugs and leads work correctly in the two left hand cylinders but not in the two right hand cylinders if that makes sense? All four of the leads can be heard to spark when not connected to the spark plugs, so guess that should rule out distributer cap,
Posted 20 August 2010 - 04:29 PM
