Cobra Clubman Seats
12 replies to this topic
#1 dr pepper
dr pepper
  • 34 posts
Posted 24 August 2010 - 12:33 PM
Hey, i was wondering if anyone could share their experience, thoughts or photos of these seats. I am looking at buying them as
1) style
2) safety
3) comfort
Cobra Seats
Also if i installed 2 of these would i be able to have passengers in the back? and where do the harnesses bolt to in the back?
Edited by dr pepper, 24 August 2010 - 12:34 PM.
#2 clubby_1275gt
clubby_1275gt
  • 132 posts
Posted 24 August 2010 - 02:21 PM
dunno what seats u mean exactly but i have these seats and as u can see there is plenty of room in the back
#3 andymini12
andymini12
  • 812 posts
Posted 24 August 2010 - 02:59 PM
this is what i asked thought it might help.
http://www.theminifo...p;#entry1912124
andy
#4 jacko616
jacko616
  • 46 posts
  • Local Club: Chichester Mini Club
Posted 24 August 2010 - 03:05 PM
i have them in my car at the moment, however they are the only seats i have owned(other than standard). So i cant comment in comparison to other seats.
I find the seats very comfy, and i find most people who get in my car do aswell. i've done 5 hour drives to Newquay with no problems.
If you get tilting subframes like i have they do, obviously tilt forward. However due to the height they hit the roof when tilted forward. But if you slide them all the way forward and then tilt you can squeeze in the back. It is a squeeze mind.
Harness wise your not really going to be able to have rear passengers and harnesses safely. Usually they mount to the rear seatbelt mountings. So if you use eye bolts and harnesses with hooks you could use harness when there are no passengers and then unhook and use normal seat belts when you have passengers.
pics here
http://www.theminifo...howtopic=165005
Edited by jacko616, 24 August 2010 - 03:06 PM.
#5 dr pepper
dr pepper
  • 34 posts
Posted 25 August 2010 - 07:32 AM
jacko616 do you just use normal seat belts with your cobra's? Also do you ever change to harnesses at all? Also i have a 1970 morris mini k that doesn't have seat belts in the back for harness mounting?
#6 frog998
frog998
  • 595 posts
Posted 25 August 2010 - 08:25 AM
I use to have these seats in a previous mini, personally i love them.
Get them with a lockable subframe and you cant go wrong, it did help though that i used to live about 2 miles from the factory and they had a yearly end of line stock around November time
#7 imvarma
imvarma
  • 153 posts
  • Local Club: Tatsu
Posted 25 August 2010 - 09:29 AM
I have these seats for my clubby estate, They look great, seem quite solid and are comfortable enough, but comfort in a bucket seat often depends on the size of your arse...
The OEM Recaros in my teg are much more hugging and supportive, but far too expensive for me to put in the mini.
#8 Wright&Wright
Wright&Wright
  • 309 posts
  • Local Club: Central Mini Owners Club
Posted 25 August 2010 - 11:25 AM
If you're going to fit harnesses you're going to have to fit a roll cage. Unless you're planning on fitting expensive inertia locking harnesses.
The harness will effectively lock you into place, meaning if something were to happen, eg. You go into the back of a lorry, you would be physically unable to move out of the way of incoming objects through the windscreen or if you rolled the car, you would not be able to duck in the seat to avoid the roof collapsing in on you.
Obviously there's no physical reason as to why you can't fit harnesses without a roll cage but I wouldn't advise it.
Oh yeah and you can't lean forward to see out of junctions either so bare that in mind :D
Greg.
#9 dr pepper
dr pepper
  • 34 posts
Posted 25 August 2010 - 11:32 AM
hmmmm fair points there wright and wright
#10 jacko616
jacko616
  • 46 posts
Posted 25 August 2010 - 12:19 PM
My car is my daily drive so i use normal seat belts for ease of use.I dont have any harnesses at the mo but im hoping to get some soon.i dont have rear seat belts as my mini is an 86 but the mountings are still there in mine. You could use these.
http://www.minisport...fo_SAB4502.html
#11 dr pepper
dr pepper
  • 34 posts
Posted 25 August 2010 - 12:36 PM
yea im leaning towards using standard seat belts for now.
#12 tony13
tony13
  • 267 posts
Posted 25 August 2010 - 05:09 PM
1) style
2) safety
3) comfort
Cobra Seats
i have got these in mine and find them really comfy . i can get people in the back but i dont use the harness , i just use normal seat belts.
tony
#13 connor.weeks
connor.weeks
  • 76 posts
Posted 25 August 2010 - 05:18 PM
is there a technique to getting people in the back because i cant get people in the back the seats wont tilt up very far because of the roof and they dont slide forward far enough to get peoplein that way ?
