Rear window demister
15 replies to this topic
#1 Cookie Monster
Cookie Monster
  • 244 posts
Posted 30 November 2005 - 04:18 PM
I have 2 minis both with rear window demisters that don't work but everything else does so its not likely to be a fuse.
Any suggestions
#2 Clubby1275GT
Clubby1275GT
  • 1,176 posts
  • Local Club: Birmingham Mini Owners Club / Bruuuums Mini's
Posted 30 November 2005 - 04:24 PM
in the same boat mate, the light on the console comes on when i press it to heat the windscreen but no joy i dont think!
#3 Jammy
Jammy
  • 25,397 posts
Posted 30 November 2005 - 04:37 PM
I think the connections at the side of the rear windscreen usually get disconnected.
#4 Cookie Monster
Cookie Monster
  • 244 posts
Posted 30 November 2005 - 04:41 PM
No, all connected, telltail lights work just nothing at rear screen.
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
do you have voltage at the screen ? :angry:
#6 MINImayfair1988
MINImayfair1988
  • 523 posts
Posted 30 November 2005 - 04:42 PM
same here if ne one got a solution it welome here lol i just use a shami lol
#7 Cookie Monster
Cookie Monster
  • 244 posts
Posted 30 November 2005 - 04:44 PM
Must admit, haven't checked voltage yet, just though someone may have had same prob and a quick fix.
Sounds like I am not the only one though
#8 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 30 November 2005 - 04:48 PM
holly i can check yours if you are this way or i will look next time we are at a cmc meet
#9 MINImayfair1988
MINImayfair1988
  • 523 posts
Posted 30 November 2005 - 04:50 PM
thank you lol dad cant fix it the back window went in alright tho!!!!
#10 ian
ian
  • 676 posts
Posted 30 November 2005 - 04:58 PM
if you have power at the screen try cleaning the screen with white spirit, wipe it over then leave it to dry, ive done this before and worked fine after, just a thought
#11 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 01 December 2005 - 12:24 PM
You really got to put a volt meter on it, or a bulb connected to the connections..
switch on, if it does not light (check the bulb on the battery) then you got no power coming in..
meter is about 4 quid for a digital one from maplins..
A must for a mini owner.
If it is not that i.e. you have voltage....
then the element could have a break in it..
again a volt meter on continuity on the terminals should give you a reading (less than 1)..
no reading and you have a break in the connection somewhere..
you can push the meter lead pin into the element (thick part) and track down the break..
once you find it you can get a heater element repair solition from Maplin (about 5 quid) you just paint this stuff over the break ..
sounds long winded but it is actually pretty simple..
hope this helps..
shaz
#12 danny987
danny987
  • 120 posts
Posted 01 December 2005 - 06:55 PM
yeah that paint stuff doe swork becus ive had the same prob n went 2 auto window screens and that was the advise they gave me.
#13 Cookie Monster
Cookie Monster
  • 244 posts
Posted 01 December 2005 - 10:50 PM
Cheers, have got a meter but a bit to wet to check ATM
#14 Cookie Monster
Cookie Monster
  • 244 posts
Posted 03 December 2005 - 03:05 PM
Right, have power at screen
Have a good earth
Have continuity (less than 1) from side to side
Still not working.
Will get soeme repair liquid and paint it on next but so far no indication as to why not working.
#15 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 03 December 2005 - 04:09 PM
next remove just one plug on the heater and see if theres any voltage petween the lose plug and the screen heater :erm:
