This time whenever I stop the car seems to have an erratic idle and then, giving it 15 seconds or so it cuts out. It's most likely the shear amount of water on our roads at the moment - yet the car in itself runs just fine.
Any things to check before I go away tomorrow just to make sure the car is in good health and hopefully cure this problem. I assume it's an ignition problem.
Thanks, Dave.
EDIT: Oh, the car is a 1990 998. All standard ignition minus the removal of the Ballast system (now has a 12v coil).
Edited by dsgoody, 26 August 2010 - 08:29 AM.
