Posted 27 August 2010 - 07:36 AM
check all connections first, inc RCA's, power connections etc.
Usually, crackling speakers is a failing flexi-lead (the thin braid wire inside the speaker going from terminal posts to the coil). luckily, most of the time, it is where it joins the post that fails, so i 'dab' of solder can usually fix that. it's just where it's been flexing most. usually from over-driving the speaker. (no need for sub-bass going into components or co-ax's)
Also, cheap RCA's have been a problem in the past as the centre wire is really thin and this fails after a while.
But these problems don't usually happen in pairs! so if your front speakers both started crackling at the same time, do as someone mentioned earlier and swap the speakers over, if the crackles go to the other pair, then after checking connections it may well be the amp.
