Fitting A Tow Bar To A Mini With A Centre Exit Exhaust
15 replies to this topic
#1 booton
booton
  • 913 posts
Posted 26 August 2010 - 10:00 PM
ok i have a 1982 mini mayfair i have a 1"3/4 striaght centre exit exhaust.
i looking in to a mini trailer was wondering u think it would be possible to fit a tow bar with out changing the exhaust.
as the exhaust is brand new and been offered a mini trailer.
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 26 August 2010 - 10:04 PM
not unless your going to fit the tow bar off centre
#3 booton
booton
  • 913 posts
Posted 26 August 2010 - 10:13 PM
i don't think u can put them off centre , and i think it would look a little strange and be a bit hard to drive/ park.
there must be a way around it
so that the tow bar come out on top of the exhaust
#4 SolarB
SolarB
  • 1,387 posts
Posted 27 August 2010 - 07:51 AM
I think Bungle might have been a little sarcastic here.
You cannot fit it off centre and it you fitted it in the centre you'd have to drop the exhaust pretty much onto the ground to get the clearance.
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 August 2010 - 08:22 AM
I'm afraid it's one or the other but not both....
#6 booton
booton
  • 913 posts
Posted 27 August 2010 - 09:34 AM
what if i made my own tow bar.
two bars that go either side of the exhaust, bend up and then join above the exhaust.
tha should work.
the toe bar would be the same lvl as the chrome bumper
i currently have a large square fog light above my exhaust, could put it there.
a bit of work tho
#7 kez_19
kez_19
  • 946 posts
Posted 27 August 2010 - 09:38 AM
not sure you are allowed by law to make your own towbar i am fairly sure that they need to have been tested to a TUV standard
i await now someone that can confirm or otherwise this
michael
#8 booton
booton
  • 913 posts
Posted 27 August 2010 - 09:39 AM
i spent last night doing some reading and i came to the conclution that if the car is before 93 then u could use one that has not been tested.
#9 nickcooper
nickcooper
  • 132 posts
Posted 27 August 2010 - 03:10 PM
there was a section in mini world a while back which told you how to make your own tow bar, fitting it to the subframe, i dont see why youcant make it stick out more like you say
#10 booton
booton
  • 913 posts
Posted 27 August 2010 - 05:15 PM
tha would be great u don;t know which month it was do u thanks steve
#11 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 August 2010 - 08:10 PM
I have a factory fitted tow bar on my 96 spi - and in my opinion its absolutely hideous!
You will need to consider how the tow bar attaches to the sub frame, as it wont just weld or bolt onto the rear. for example mines has a square bar through the whole rear subframe which wlll also have implications for where the exhaust back box should be.
Also if you have paid good money for a nice pretty centre exit exhaust why taint it with a ugly tow bar. I assume you wont have the trailer more often than you will.
Personally i would remove mine, but its a bit of a hassle to inform the swedish dvla.
#12 booton
booton
  • 913 posts
Posted 27 August 2010 - 08:44 PM
i'll make it so i cna just bolt it on and off,
#13 grumpy2
grumpy2
  • 613 posts
  • Local Club: Wirral Minis
Posted 27 August 2010 - 09:01 PM
I've been thinking of putting one on my MPi but I don't think I can for 2 reasons. Firstly the handbook specifically says the MPi isn't suitable for towing so I guess this would invalidate my insurance. SEcondly I can't find any company who supply a towbar suitable for the Mpi model.
so I guess no towbar for me!
G
#14 josh.evans
josh.evans
  • 1,439 posts
Posted 27 August 2010 - 10:31 PM
hi i was thinking about this a few months back as i have a centre exhaust mra minis were going to build me one give them a ring or pm then on here
josh
#15 Abminis
Abminis
  • 89 posts
Posted 28 August 2010 - 07:59 AM
on my mini thirty
it has a tow bar fitted with two bars running under the car
when i bought the car it had a ctr exhaust fitted it looked good
i will try and find a old pic
hope this helps
[attachment=102181:3e81_1.jpg]
[attachment=102182:af11_1.jpg]
Edited by Abminis, 28 August 2010 - 08:00 AM.
