I decided to replace my standard diff with an X-pin one from Minispares (reusing my old output shafts). First time I've assembled a diff and was surprised how straight forward it was... until I tried to turn the output shafts once assembled. I had expected to it to spin very smoothly/quietly like my old diff did, but it's very noisey/notchy (can feel every tooth engage as you spin it). On first assembly I could spin it by hand with great difficult and it would bind at one point in the cycle. Dismantled it and felt like the bronze washers were catching a little on the planets... so I used some Barkeepers Friend to cut/match each washer to its planet. That got rid of the binding point in the cycle - I can now spin the whole cage (hold the ouput shafts vertically, spin the cage by hand and it runs for a few cycles)... but it's still noisey/notchy (sounds a bit like an old football rattle).
Is that normal? I'm a bit worried that if I do mate it up to the box "bad things" will happen when I put power through it.
If it's not normal then what's the cause, and how should I fix it (maybe new output shafts... hopefully ones whose teeth match the planets a bit better)?
I'm pretty sure the thrust washers on the output shafts aren't the cause... I used one from the old diff (would have used the other too but I've mislaid it!), and one from the new kit which was the same thickness as the used one (a tad under 34thou). Even before I bolted the crownwheel in place the "problem" can still be felt/heard.
Cheers,
Colin.
Edited by colinu, 28 August 2010 - 07:43 AM.
