Ball Joint Splitters
Posted 31 August 2010 - 01:04 PM
Posted 31 August 2010 - 01:09 PM
Posted 31 August 2010 - 02:12 PM
I've never used the cup type.
I have used the fork type. They can be awkward and you have to pound the crap out of them....good for heavy duty equipment I guess.
Posted 31 August 2010 - 02:14 PM
However, with any screw-type splitter like this, don't expect tightening the bolt on the splitter to do all the work. Loosen the ball joint nut but leave the nut on the ball joint stud to prevent damage to the threads. Tighten the splitter up very tight, then use a hammer to "whack" the bolt on the splitter. The mechanical shock to the joint under tension will usually separate the parts. Tightening the splitter without the hammer blow may just frustrate you.
Posted 31 August 2010 - 02:45 PM
Posted 31 August 2010 - 03:06 PM
Posted 31 August 2010 - 04:10 PM
Posted 31 August 2010 - 06:39 PM
Posted 31 August 2010 - 07:16 PM
I used a company called PVR Direct.co.uk and bought a Draper Ball Joint Splitter part No 63770 cost was £11.32 + VAT.
Also bought the double depth socket to undo the ball joint. Draper part No 26916 £8.23 + VAT.
With PVR Direct your first order was delivery charge free if you sign up. I could not find the tools cheaper elsewhere.
Posted 31 August 2010 - 08:18 PM
A big hammer is best a good hard bash on the side. If this dosent work i usualy get a long bit of box section or bar and leaver on something and hit it helps with more than one person to do this, failing that a big hammer and lots of heat or combination of the three. Dont think i have ever used or needed a spliter.
i second the big hammer
Posted 31 August 2010 - 08:33 PM
OOps sorry adam101 didnt read your post fully! looks like i wil be ordering a draper one up then!
Edited by 206boyracer, 31 August 2010 - 08:36 PM.
Posted 31 August 2010 - 08:39 PM
Worked no probs as well.
Posted 31 August 2010 - 10:54 PM
I dont think my mate enjoyed falling backwards onto all the tools behind him the other week when he borrowed mine
Edited by Darkscamp, 31 August 2010 - 10:55 PM.
