Red Oxide?
14 replies to this topic
#1 chadders15
chadders15
  • 393 posts
Posted 01 September 2010 - 07:06 PM
What Red Oxide is the best to use??
Or is Hammerite better
Or both?
#2 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 01 September 2010 - 07:21 PM
i dont know at every1 else does but i myself am goin to take the precaution nd use both just in case
#3 bikecrazy100
bikecrazy100
    Starting My Mini Up
  • 3 posts
Posted 01 September 2010 - 07:37 PM
Hi, hammerite do their own primer called rustbeater, some red oxide primers won't take hammerite on top as it will react and wrinkle, best of luck Tony. (bikecrazy100) also painter & decorator.
#4 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 01 September 2010 - 07:38 PM
Your question relates to two different types of paint.
Red oxide is a primer, Hammerite (generally) is a top coat although they do make a primer specific to their brand as well I believe.
Moved to Bodywork, Paint and Detailing.
#5 chadders15
chadders15
  • 393 posts
Posted 01 September 2010 - 07:40 PM
Oh right OK
(Thanks for moving)
#6 mk3cortina
mk3cortina
  • 677 posts
Posted 01 September 2010 - 07:43 PM
im currently going through a tin of red oxide from wilkinsons, cost like £3.50 for a 500ml tin. a lot cheaper than B&Q who charge about triple that. beleive me, i checked.
#7 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 01 September 2010 - 07:49 PM
im glad i aint bought hammerite yet then but i got told about a paint the army use that clings to any surface and as long as its in a place with no sunlight is guaranteed to protect from rust anywhere it put :) :dontgetit:
#8 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 01 September 2010 - 08:09 PM
Tell us more!
#9 miniman24
miniman24
  • 1,696 posts
Posted 01 September 2010 - 09:48 PM
im glad i aint bought hammerite yet then but i got told about a paint the army use that clings to any surface and as long as its in a place with no sunlight is guaranteed to protect from rust anywhere it put :D ^_^
Tell us more!
Sounds like POR 15 to me :( Never used it though, too expensive for a student :lol:
#10 mk3cortina
mk3cortina
  • 677 posts
Posted 01 September 2010 - 09:50 PM
join the army, then you could just take gallons of the stuff.
#11 K18ARY
K18ARY
    Just On Tickover
  • 7 posts
Posted 02 September 2010 - 10:39 AM
On a slightly same but different note, can you paint POR15 on top of Hammerite.
I find hammerite to be ok but it chips so easily. I am not bothered about finish, just want to make sure my new subframes are caked in the stuff!
#12 SolarB
SolarB
  • 1,399 posts
Posted 02 September 2010 - 03:55 PM
POR15 is very good but can only be applied to rust or properly prepared clean metal. You have to follow the instructions precisely to get the full benefit of the system but applied properly it’s superb stuff.
#13 mk3cortina
mk3cortina
  • 677 posts
Posted 02 September 2010 - 04:45 PM
what would be the point in putting POR15 over another paint, kind of defeats its purpose.
#14 me madjoe 90
me madjoe 90
  • 1,238 posts
  • Local Club: Fylde Mini Club
Posted 02 September 2010 - 04:46 PM
Boat builders use an anti rust primmer thats rich in ZINC heard its good stuff most marine stores sell it realtivly cheap and alot of them can be used with nearly all other paint types without reaction. Now if it can stop boats (constanly wet) rusting then surely it would protect a mini.
"(Zinc Rich) Primers
For underwater protection boat builders will tend to use zinc primers. These will contain 90% zinc by weight and offer some degree of cold galvanising protection. They are available in epoxy or natural thinned. The natural thinned paint is said to be more effective, but it's adhesion is poor - it is important to sand blast the bare metal surface to provide a rough surface for the paint to bond to, otherwise it can be scraped off with a finger nail. Any exposed areas should be overcoated in anti-stonechip paint." Qoute from this site - http://www.mig-weldi...o.uk/primer.htm
Examples of such paints
http://marinestore.co.uk/HA1326.html
Note : Apply to bare metal like all primmers should and are used for....
Edited by me madjoe 90, 02 September 2010 - 04:48 PM.
#15 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 02 September 2010 - 07:24 PM
I would avoid using standard red oxide from DIY stores (B&Q/ Wilkinsons and the like) for automotive use, as it takes forever to fully dry/set, causing problems when you try and sand it down or spray paint. You can buy an automotive red oxide though that is cellulose based, this is much better and dries enough to allow gentle sanding and over-painting in a matter of minutes.
