Gears Popping Out On Deceleration
Posted 01 September 2010 - 08:34 PM
Been pointed at it being the syncros not gripping properly, which would be an engine out job, obviously. Gearbox is newly restored, from an SPI engine, standard 4 gear box. 1st and 3rd gear work flawlessly.
Any ideas?
Posted 01 September 2010 - 08:36 PM
Posted 01 September 2010 - 08:43 PM
Posted 01 September 2010 - 08:54 PM
the fact its doing it in 2nd and 4th points to engine mounts/steadys.
Had that idea too, thing is, we have fitted two additional lower engine steadies left and right to the subframe. Selector rods are checked and ok too. Even added a washer to make the upper rod a tad longer so it would be harder for 2nd and 4th to be kicked out by the engine moving backwards. Didn't help...
Posted 01 September 2010 - 08:56 PM
Posted 01 September 2010 - 09:00 PM
you could bungee strap it to the handbrake
That would probably work, as holding the gearstick helps too, obviously. But bungeeing it back would probably make 1st and 3rd pop out, which would be just as bad. I'm looking for a permanent solution, really:)
Posted 01 September 2010 - 09:03 PM
Posted 01 September 2010 - 09:20 PM
also its worth removing the gear stick gaiter and seeing where the stick sits in relation to the hole in the body, I have seen the remote colut the body when the engine moves before and knock the engine out of gear.
Posted 01 September 2010 - 10:55 PM
Posted 01 September 2010 - 11:07 PM
And who 'restored' the gearbox ?? Take it back to them and tell them to fix it!
Yes Sergeant Major General Sir, Right Away Sir!!!
Posted 01 September 2010 - 11:09 PM
Posted 02 September 2010 - 09:03 AM
Well, obviously, taking the engine out of the car, removing the gearbox and having it fixed is going to be the last thing I will try. Would be rather stupid to go for that and then find out that it was just the wrong length dogbone or somesuch.
As for the gearlever: We did look into this and even exchanged the whole selector housing and rod. Fitting a K&N quickshift hasn't helped either. The stick is moving freely and not bumping against the bodywork or the housing anywhere. If that was the problem, it would probably pop out of reverse, too, which is not the case.
Worn selector forks sounds interesting, although that would also mean taking the engine out. I will now try and exchange/loosen/tighten the engine stabilizers during the weekend and see, if that has any effect. If not, I guess we will find out once the gearbox is off...
Thanks for your replies so far.
Posted 02 September 2010 - 04:32 PM
Posted 02 September 2010 - 04:45 PM
jack
Posted 02 September 2010 - 05:02 PM
