Steering Wheel Doesn't Sit Correct
Posted 05 September 2010 - 08:02 PM
I've managed to get my mits on a 99 mini Paul Smith and I love it but there is one little thing that bugs me when driving in a straight line the steering wheel seems to be turning slightly to the right. It has an airbag so it's not as easy as just undoing a nut and moving it around slightly. Does anybody know what may be wrong and if I do need to take it off how is this done with it having a airbag.hope you guys can be of help because you never usually fail.
Regards
Scott
Posted 05 September 2010 - 08:05 PM
Take the car to a decent garage and get them to set it properly. Shouldn't cost too much.
Posted 05 September 2010 - 08:09 PM
It won't be the steering wheel, they only go on one way. It'll be the tracking.
On the later models?
Mine is a 1990 and I could have it upside down if I so wished. When did airbags come in?
Posted 05 September 2010 - 08:10 PM
Posted 05 September 2010 - 08:22 PM
Scott
Posted 06 September 2010 - 06:26 AM
by the way, airbags were introduced with the mpi engines, approx 1996.
Hth
Ryan
Posted 06 September 2010 - 06:51 AM
Posted 06 September 2010 - 12:41 PM
Posted 06 September 2010 - 09:12 PM
Posted 06 September 2010 - 09:20 PM
Posted 06 September 2010 - 09:48 PM
i had my tracking done on saturday as the car has been pulling to the left,
the car was done with lasers and computers and by a lad who built a mini (i feel it was in good hands)
however the car still moves to the left, like above the steering wheel sits to the left and you have to steer to the right slightly to go in a straight line.
could this be a dodgy steering rack?
Posted 07 September 2010 - 09:28 AM
can i hijack for a brief time?
Not sure to be honest. Mine goes in straight line when i take my hands off the wheel (not advised ;p) But the wheel sits turned to the right a little (at about 1 clock)....something isn't right thought because my tyre shouldn't be worn like that...
Posted 07 September 2010 - 09:49 AM
It's a good idea to check that the steering wheel is on in the right place- it is splined to the column so can be 'out' by any amount.
Pull up the carpet on the passenger side and find the rubber grommet, sort of where your passenger's right foot would rest. If you remove this grommet, you'll reveal a hole through to the ground, obscured by the steering rack itself, and a plastic bung.
Unscrew this bung and see if you can insert a (6mm?) drill bit in the hole. Wiggle the steering wheel and it should drop down a little.
If this locates, you've found the centre position of the rack and the steering wheel should be dead level.
If the wheel is wonky, refit it in the correct position. If it is level, it's fine and probably just a tracking adjustment is needed.
Remove the drill bit, screw in the plug and push the rubber grommet back into the hole, making sure it seals.
While you have the carpets up, check the 4x 1/2" nuts which secure the steering rack to the body (two nuts on each side of the floorpan) are tight. Same goes for the 'pinch-bolt' at the base of the steering column.
Posted 07 September 2010 - 09:56 AM
Posted 07 September 2010 - 09:59 AM
Normally, the wheel sits off-centre because the track rod adjustment at the front is not equal side to side, ie there are more threads showing on one side than the other, but there's not a lot you can do about that unless you have your own stuff.
And a final point to depress everyone further! - the car is mainly guided/ steered by the back wheels when it's going along 'straight' anyway!
