Flashing Coloured Led's In Back Lights?
16 replies to this topic
#16 hylsan
hylsan
  • 82 posts
  • Local Club: Mini Club Sweden
Posted 08 September 2010 - 07:32 PM
Ok, then its a piece of cake >_<
Can you solder, do you have any electronically skills?
This kit should do the trick (its a 10-channel running light but can be modded)
http://www.quasarele...g-light-kit.htm
but you have to assembly it yourself, it looks quite simple tho.
you have to do small adjustments tho to fit your application (ie change some resistors due to the fact you want more LEDs per channel)
Im gonna continue looking if I can find a built kit or something...but now you have something more to look at :P
more reading ...shows how it works...
http://www.delabs-ci...s/doc00020.html
Edited by hylsan, 08 September 2010 - 07:44 PM.
#17 hylsan
hylsan
  • 82 posts
Posted 10 September 2010 - 04:13 AM
very easy and modular design, but still you have to do it yourself...
http://www.diy-elect...Lamps-Sequencer
here you can make it just for three clusters with several LEDs in each cluster. if you want to vary the speed you could simply use a variable capacitor.
