Sealey 140 Supermig
6 replies to this topic
#1 steve26-2008
steve26-2008
  • 42 posts
Posted 06 September 2010 - 09:24 PM
Does anyone own a sealey 140 supermig? I would like to know what the wire feed is like on these machines, as I want it to replace my sip welder which is rubbish.
#2 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 07 September 2010 - 07:30 AM
most of the small welders tend not to have wonderful wire feed to say the least, to be honest doubt you would notice much difference.
#3 jayare
jayare
  • 2,093 posts
Posted 07 September 2010 - 09:47 AM
Have a look over on mig-welding.co.uk - most people seem to recommend Clarke as having the best wire feed for hobby welders. I have a Clarke 160TM which I bought off the Weldequip shop on there and have had no problems with it,
JR
#4 Danpolk
Danpolk
    Previously known as 206boyracer
  • 220 posts
Posted 07 September 2010 - 10:58 AM
I have been doin a lot of research into welders lately and the clarke 151te seems to be highly reccommended on the mig welding forum and many other sites! This is the one i have therefore decided to buy! The cheapest place i have found it is  www.tool-net.co.uk
#5 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 07 September 2010 - 11:28 AM
i just bought a clarke 150 t from tool net and i cant fault it
#6 jonjosar
jonjosar
  • 137 posts
  • Local Club: Not yet
Posted 08 September 2010 - 09:46 PM
I have a Supermig 185 and it has been brilliant. Bought it 4 years ago.
My brother uses the same one in his bodyshop and its been no bother either. If i remember, it was around £260 when i bought it. I used some of the "hobby" types before buying the Supermig and to be honest, there is no comparison. Loads of settings etc.
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 08 September 2010 - 10:02 PM
The one thing i found with the Clarke welder was when i used the 1kg spool of wire the feed was terrible so much so i ended up damaging the sleeve. However once i went to a 5kg spool then no problems. I had checked the clamp pressure and tried different pressures but it made no difference.
I do believe it was the angle the wire was feeding up to the drive wheel with the 1kg spool causing issues with the tension.
