Fog Light And Switche's
7 replies to this topic
#1 sam mayfaire spi
sam mayfaire spi
  • 11 posts
  • Local Club: middelton mini club
Posted 07 September 2010 - 12:33 AM
hi i have been trying for a wile to sort all the little things on my car and then found out that mt fog light did not work and none of the switches on the lower dash rail are lighting up i have changed the switches but makes no diffrence and i have also checked fuses and cant find any loose wires does any one know what the problem is ????
my mini is a 1995 spi mayfair
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 07 September 2010 - 06:20 AM
any power at the switches ?
#3 pikey7
pikey7
  • 3,824 posts
Posted 07 September 2010 - 03:10 PM
blownfuse? bulbs gone? do they work but just not illuminate?
#4 sam mayfaire spi
sam mayfaire spi
  • 11 posts
Posted 12 September 2010 - 10:56 PM
all the fuses in the box are fine and they all seam to work apart from the fog light ?
#5 sam mayfaire spi
sam mayfaire spi
  • 11 posts
Posted 12 September 2010 - 10:57 PM
but no they do not illuminate
#6 Ethel
  • 26,580 posts
Posted 13 September 2010 - 12:10 AM
The fog light switch is fed by a blue wire from the headlights so you can only turn it on if they are.
#7 sam mayfaire spi
sam mayfaire spi
  • 11 posts
Posted 15 September 2010 - 11:43 PM
i have made sure that they are on first and still nothing :P
#8 sam mayfaire spi
sam mayfaire spi
  • 11 posts
Posted 24 September 2010 - 12:05 AM
YAY :D after week's and week's i have managed to fix the problem well i had one of thoes wake up in the middle of the night things happen and i realised tho the fog light bulb was holding in the contact at the end may not have been touching and so i took the light apart and sure enough it was not touching so just bent that and its working fine :thumbsup: and have also fixed the switche light's :( (same night) i had a funny thougt ..... hummm they are ment to have a wire to both sides of the switch to make the light on them work so maybe as i am pushing them in to the dash they are coming off so pulled them all out and had a look and sorted the wires so they are now all neat and tiday and they dont come off as i push them in :P so all is sorted o and i forgot that i had to put the fuse back in the fuse box to make the fog light work lol so this problem is solved so thank you to everyone who helped :wacko:
