Turning Engine Over By Hand
Posted 07 September 2010 - 03:04 PM
Just bought this car as a non-runner. I know that the previous owner had the distributor out and that there is apparantly a loose clutch, so thought the first thing to check is the static timing. Engine turns over ok on the key so I know it's not seized, but I can't turn the thing over by hand no matter what I try!! I can't rock the car with it in gear as the clutch must be seized - pedal is solid and car rolls in gear without engine turning over. I thought with the plugs out I'd be able to turn it with the fan but I just can't get any movement at all and to cap it all the bottom pulley has been welded to the crankshaft so there's no nut on there that I can use.
Any hints or tips chaps?
Posted 07 September 2010 - 03:30 PM
have you tried using a spanner/socket on the alternator bolt?1990 mini with 1275 metro engine (or is it 1300?)
Posted 07 September 2010 - 03:45 PM
Posted 07 September 2010 - 06:14 PM
Posted 07 September 2010 - 06:16 PM
Posted 07 September 2010 - 06:28 PM
Edited by liirge, 07 September 2010 - 06:36 PM.
Posted 07 September 2010 - 06:32 PM
Posted 07 September 2010 - 06:36 PM
