Camshaft Timing, How Far Am I Ok To Be Out By?
Posted 07 September 2010 - 08:04 PM
Posted 07 September 2010 - 08:05 PM
Posted 07 September 2010 - 08:08 PM
Posted 08 September 2010 - 05:37 PM
Steve
Posted 08 September 2010 - 07:45 PM
It's always best to time a cam in a couple of degrees advanced from the manufacturers recommended setting as a new timing chain will stretch a little an retard the timing as it does.
Steve
Yep, I agree with that, if it's a new timing chain then 104 degrees will be fine. And if it's not a new chain and it doesn't stretch then a slightly advanced cam isn't such a bad thing anyway, it's better for mid range pull at the expense of a bit of power at maximum RPM, which is something that's worth having a million times over, instead of a couple more BHP at 6000RPM or thereabouts.
Posted 08 September 2010 - 07:49 PM
i spent 3 and half hours getting mine absolutely dead on, so i get the most out of the cam. it seems silly not to get it as close as possible whilst the oppurtinities there.
Edited by samsfern, 08 September 2010 - 07:59 PM.
Posted 08 September 2010 - 07:57 PM
I spent ages timing mine in aswell to get it spot on.
Edited by Pauly, 08 September 2010 - 07:57 PM.
