Metro Drive Flange
1 reply to this topic
#1 Adzion
Adzion
    Starting My Mini Up
  • 1 posts
Posted 07 September 2010 - 08:57 PM
hey
Sorry if this seems like a daft question. I have brought what i beleive to be a metro turbo conversion kit, it is for the vented type discs. I have the vented discs, 4 pot calipers and i am using a mk2 wheel hub.
the problem i have is that when i tighten up the wheel/disc locking nut, the inside of the disc brake locks up against the lower arm that surrounds the drive shaft.
i am fitting this to a 998cc C reg mini mayfair..
hope thats all the information
thanks
adam
#2 Ethel
  • 26,580 posts
Posted 08 September 2010 - 01:35 AM
Not clear about what the problem is, perhaps a piccy would help.
To fit Metro vented discs to a Mini (with 8.4" discs) you need the vented discs; the calipers & the drive flanges (with wheel locating lugs removed). You'll also need to use ERA Turbo Mini caliper bolts (if using iron calipers off a Metro). The drive flanges must be for vented discs.
