Fuel Filter Problems
14 replies to this topic
#1 DaveJH
DaveJH
  • 393 posts
Posted 08 September 2010 - 12:04 PM
The fuel filter on my SPi 1996 seems impossible to unscrew from the pipe leading to the tank so I want to just rip that pipe out and replace it but after talking to Mini Spares it appears they have none in stock and may not have anymore in stock anytime soon as apparently Rover are going to discontinue the item. What can I do to fit my new fuel filter? I think I've damaged the old one trying to get it off as I now have a leak when the car is running so it has to be changed but I don't know what to do about that pipe.
#2 njathind
njathind
  • 447 posts
  • Local Club: Chichester Mini Club
Posted 08 September 2010 - 12:59 PM
As a temprary measure I would remove the filter and replace it with a fuel hose and then put a inline filter in place of the factory one, then see what you can do from there, I am also waiting on the spi/mpi fuel filter aswell.
#3 icklemini
icklemini
  • 2,982 posts
Posted 08 September 2010 - 01:42 PM
well there is a little trick in that you use a fuel filter without screw connections...
Got the part number written down at home somewhere... think its of a pug or a renault, same physical dimensions, but rather than screw fittings they have pipe ends... so use some hose and jubilee clip it in place... simples...
#4 DaveJH
DaveJH
  • 393 posts
Posted 08 September 2010 - 06:17 PM
Sounds good icklemini, let me know if you remember the part number. At least then I can easily replace it in a couple of years when I need to without having to worry about stuck screws again.
#5 icklemini
icklemini
  • 2,982 posts
Posted 09 September 2010 - 06:32 PM
Have a word with the parts man for a WIX WF8034 - should be a renault clio fuel filter... i *think* the halfords equivalant is HFF217 (in fact if you do go for halfords, you can get the proper spi one and compare.. :trooper: )
Need some fuel injection hose (8mm) and clips...
#6 DaveJH
DaveJH
  • 393 posts
Posted 09 September 2010 - 07:51 PM
Brilliant, I'll try and get hold of some tomorrow then. Thanks for the help!
#7 DaveJH
DaveJH
  • 393 posts
Posted 15 September 2010 - 11:46 AM
New fuel filter is on but now the fuel pump wont work, therefore he won't start! Any advice? :thumbsup:
#8 Ipod
Ipod
  • 2,024 posts
Posted 15 September 2010 - 05:21 PM
Are you sure, you aint caught a wire refitting the tank?????
#9 icklemini
icklemini
  • 2,982 posts
Posted 15 September 2010 - 06:32 PM
what would you have done to disturb the fuel pump?
check wiring... check the cut out switch...
#10 Ipod
Ipod
  • 2,024 posts
Posted 15 September 2010 - 06:34 PM
My money is on either a broken wire or blown fuse
#11 DaveJH
DaveJH
  • 393 posts
Posted 16 September 2010 - 12:50 AM
The thing is, I haven't touched the tank since just before I changed the filter so I can't see why that would be the case. I checked all the fuses and I checked the wire from inside the car to see if it had power there and it didn't seem to but I'm not sure. I assume the fuse for the pump is in the fuse box in the engine bay?
#12 DaveJH
DaveJH
  • 393 posts
Posted 17 September 2010 - 10:47 AM
He has started working on his own again today. Perhaps there was a block somewhere that forcing the pump to work full time off the battery has been pushed through. Thanks for your help.
#13 Ipod
Ipod
  • 2,024 posts
Posted 17 September 2010 - 12:15 PM
Happy endings :D
At least now you know you have a fuel cutoff swtch
#14 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 17 September 2010 - 01:07 PM
You may be able to get a new one made up by someone like pirtek if you take the old one along for a pattern,worth a go.
#15 DaveJH
DaveJH
  • 393 posts
Posted 17 September 2010 - 02:29 PM
Er... a new what? :D
