Head Gasket Blown :(
Posted 08 September 2010 - 01:56 PM
We did have the head off to have unleaded valve seats put in (done by Slark Race Engineering) it was skimmed at the same time too.
Replaced the head gasket, studs and nuts all at the same time. Torqued down very carefully in the correct order to the correct torque too.
The car has moved about 1/4 mile with the engine running, but due to it running to rich I did not drive it anywhere.
I have not taken the head off yet (due to work commitments) but I would dearly like some help. I do not understand why this would do it?
The chap who was tuning it said its only another half hour away from being spot-on. Just always something got to come along and ruin it eh!?
Could anybody enlighten me on what may cause a thing like this?
Posted 08 September 2010 - 03:02 PM
ignore this, I was apparently wrong, the rivet just holds the bits underneath the cap on.
Do you know what the water temps were at?
Edited by Cerberus, 10 September 2010 - 06:50 PM.
Posted 08 September 2010 - 03:31 PM
I believe the 'brass rivet' on the top of the cap is part of the pressure valve. Cooling system caps are rated at different pressures to allow the cooling systems to work correctly, something to do with the fact that under pressure water boils at a different temperature.
Well the chap doing the rolling road said there was nothing wrong with the water temp. So I guess it was normal temp?!
Posted 08 September 2010 - 03:33 PM
when mine went the temp shot up though........
Posted 09 September 2010 - 08:58 AM
if water is coming out near the steady it could be a split bypass hose (if fitted)
No the other side, where the standard engine steady is fitted (onto the master cylinders)
Anybody got any help?
Posted 10 September 2010 - 05:51 PM
Posted 10 September 2010 - 07:24 PM
engine core plug?
This man could be onto something - think there are 2 on that side of the block!
Posted 11 September 2010 - 10:44 AM
engine core plug?
No its not a core plug, it was coming out of the join between the head and the block!
