Lambda Gauges?
11 replies to this topic
#1 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 08 September 2010 - 06:44 PM
Well, due to noticing how skint i am recently, i'd rather not shell out £200 for a rolling road session.
So, to allow me to tune my MegaJolt ECU, and carb needles, i'd like to install a Lambda gauge on my car.
My question is, where can i get one from? Has anyone on here had any experience of buying/fitting/using one?
Cheers, Paul.
#2 amarcd
amarcd
  • 434 posts
Posted 08 September 2010 - 06:50 PM
I would also like to know about lambda gauges as i'm on the Isle of Man and so have no rolling road! thanks
#3 mini13
mini13
  • 3,811 posts
Posted 08 September 2010 - 07:01 PM
A good one to get is the AEM wideband,
they are on ebay for about 150quid.
Weld the bung into the exhaust, bolt the sensor in, mount the gauge and connect it to a live feed and away you go.
the hard part is profiling the needle!
#4 amarcd
amarcd
  • 434 posts
Posted 08 September 2010 - 07:17 PM
is there anyway you can use one just to set up the carb without the need to weld and mount the sensor?
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 08 September 2010 - 07:32 PM
All the ones I've seen require the sensor fitting in the exhaust.
From what you say if its only to tune the car rather than a rolling road, I'd say the rolling road is going to work out the better bet.
The lambda will only tell you the air/fuel ratio but for profiling the needle you also need someway of knowing which section of the needle needs profiling.
Just sitting in the drive making adjustments won't be the same because you'll have non of the frictional forces a rolling road can exhert on the engine.
Saying that if its a common setup eg cam , bore size , carb thats been used by others then chances are they will know which needle works well, its just a matter of setting the tickover mixture then, gunsons gas analyser works well for that, about £80 although ebay can throw up bargains
Edited by lrostoke, 08 September 2010 - 07:34 PM.
#6 MarkGTT
MarkGTT
  • 528 posts
Posted 08 September 2010 - 07:38 PM
i use an AEM wideband, its great but to profile the needle you need to understand the how the carb works, and gauge where the needles is in the carb corresponding to the throttle being opened.
i have used this method for 2 different needle requirements so can be done.
#7 amarcd
amarcd
  • 434 posts
Posted 08 September 2010 - 07:43 PM
The the problem is there is no rolling road in the isle of man so it would mean getting boat to the UK. What are the colour tune kits like (clear sparkplug) Wheres the best place to get one or the gas analyser from other than ebay?
thanks
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 08 September 2010 - 07:49 PM
Not sure what shops you have over there, Halfords sell them here, I would think any motor accesory outlet could order one in for you
#9 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 08 September 2010 - 08:16 PM
Well as has been said, buying the full AEM kit is just as dear as a rolling road session.
Does anyone know about the inner workings of how these things function? i.e is it possible to buy this and then source a Lambda probe off a scrap car?
Cheers for all the responses so far people, appreciated.
#10 mini13
mini13
  • 3,811 posts
Posted 08 September 2010 - 08:38 PM
Unfortunantly not,
what you can do is connect a narrowband lambda sensor to a gauge for about 30 quid, but this wont tell you much, only if the engine is running above or below stochimetric.
the Wideband lambda is a sophistcated bit of kit, if you want to know more about how it works.... http://www.megamanual.com/PWC/
#11 GreenMini17
GreenMini17
    Formally known as Chris-G
  • 424 posts
Posted 09 September 2010 - 09:23 AM
Stack do a nice good quality one. See this: http://www.merlinmot...oduct_info.html
#12 Ethel
  • 26,088 posts
Posted 09 September 2010 - 10:23 AM
14point7.com are a similar enterprise to Megajolt. Innovate are good too.
Data logging to a pc will be more useful than a gauge if you want to tune your car on the road.
D-i-y dyno craftiness
