Hif44 Round The Wrong Way?!
7 replies to this topic
#1 cherylb12
cherylb12
    Starting My Mini Up
  • 4 posts
Posted 09 September 2010 - 01:26 PM
Hi all,
In the middle of fitting a standard refurbed 1275 instead of the 998. Only mods r basically a stage 1 (bbw needle, red spring, 2.5" pancake k&n, exhaust/manifold etc).
Ive recenlty purchased a refurbed hif44 carb already mounted on a manifold, however, all the pictures ive seen of the hif44 have all mechanisms and nozzles the other way around to mine. As u look at the carb with the manifold nearest you, my throttle and choke is on the left side?
Is this because its one of a twin setup, if so does this matter? I typed the part number of the manifold into google and it said its from a cooper(so not a aftermarket performance manifold as advertised?!) with the type of manifold in mind, should i have no probs with the clearence of the k&n and the bulkhead.
(I did used the search tool but couldnt find answer)
Many Thanks....
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 09 September 2010 - 02:56 PM
burlen might be able to help
#3 cherylb12
cherylb12
    Starting My Mini Up
  • 4 posts
Posted 09 September 2010 - 03:01 PM
Thanks ill check it out....
#4 cherylb12
cherylb12
    Starting My Mini Up
  • 4 posts
Posted 09 September 2010 - 03:38 PM
Couldnt really find what i wanted, im sure ill work it out at some point! Any further help would be most welcomed. Thanks...
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 09 September 2010 - 04:10 PM
did you try ringing them ?
#6 mini_adam
mini_adam
  • 198 posts
  • Local Club: fabmoc.co.uk
Posted 09 September 2010 - 07:54 PM
sounds like its from a twin setup :trooper: dont see y that would matter really
#7 cherylb12
cherylb12
    Starting My Mini Up
  • 4 posts
Posted 09 September 2010 - 08:45 PM
Thanks. No i didnt ring them, ill do that.
Hetched on the top of the manifold is : BC & M-AC/R ? Part number : CAM 6618 Will this carb maifold be appropriate for my setup? Thanks again..
#8 Nial
Nial
  • 76 posts
Posted 10 September 2010 - 01:46 PM
I've got one which I'm told is an MG Metro manifold with BC & M-AC/R stamped on the top (actually I've got
two and they both have it).
Nial.
