Indicators not flashing
Posted 03 December 2005 - 05:01 PM
I have a problem with my indicators, when i turn them on they come on ok, but they no longer flash, we though this might be to do with the flasher unit that is near the air-filter, but when i replaced that the hazards worked (which is great because they havnt worked for ages) but the indicators still dont flash! grrrrr
Has anyone got any idea what the problem could be?
Posted 03 December 2005 - 05:23 PM
Posted 03 December 2005 - 07:02 PM
firstlly the flasher for the indicators, under the dash by the pedals
secondly change the switch.
but it does sound like the flasher unit
Posted 03 December 2005 - 07:37 PM
Posted 03 December 2005 - 07:51 PM
try swapping your hazard switch, may sound silly b ut trust mei have that problem too but i changed both, all bulbs work, someone said it could be the earth?
Posted 03 December 2005 - 09:15 PM
The most common problem is poor earth, usually caused by corrosion.
Check the front indicator unit. The metal that holds the bulb is crewed to the bodywork to provide the earth. This bulb holder corrodes relatively quickly.
Changing it is a two minute job. But just to check it, eath the holder to the body with a piece of wire.
Posted 03 December 2005 - 10:00 PM
Posted 03 December 2005 - 11:22 PM
Certainly older cars had independant hazard and indicator flasher units
I would suggest that you can prove that it is not the hazard warning light swtich by the fact that if you start to actuate it all the bulbs will go out rather than staying on.
If a bulb is lower brightness than expected then this would indicate a bad eartn * although I wouldn't expect both sides to be affected)
For those people that are not aware, flasher units are designed to flasher quicker should a bulb fail
Posted 04 December 2005 - 12:37 AM
Posted 04 December 2005 - 04:34 AM
Posted 04 December 2005 - 08:37 AM
any ideas??
Posted 04 December 2005 - 10:22 PM
Posted 04 December 2005 - 10:25 PM
