1275 Head On 1100 Block?
4 replies to this topic
#1 MiniMoe
MiniMoe
  • 65 posts
Posted 12 September 2010 - 01:18 PM
I got my clubman for free but the previous owner didn't know much about cars. She tried to explain that the car has a 1275 head but on a 1000 block???? Is this possible I'm not a mini guy myself.....well not yet anyway. Just learning for now. Thanks
#2 mini13
mini13
  • 3,811 posts
Posted 12 September 2010 - 01:22 PM
it is possible, you either need to use a cam of low lift, or have the edge of the bores machined out to miss the valves.
#3 MiniMoe
MiniMoe
  • 65 posts
Posted 12 September 2010 - 03:07 PM
Mini13,
Could an 1100 do it instead? I thought all A and A+ engines were the same? I'm so confused. LOL
#4 Cooper-202S
Cooper-202S
  • 201 posts
Posted 12 September 2010 - 03:22 PM
For Clarity
A series engines fall into 2 distinct groups
Small bore -997, 850, 998(1000), 1098(1100)
Large Bore -970, 1071, 1275,
In order to fit a large bore head to a small bore block you will need to do/have done 1 of the following:
Picked a camshaft with a lift of less than the depth of the chamber in the head.
Pocketed the top of the block
recessed the valves into the head
The easy way to check is to remove the rocker cover and check the head number.
If it is a large bore head it will have a number in the center of the casting, 12G940,
If its a small bore head the numer should be in the back left corner , 12g202 ( correct for the 1100) or CAM4810 ( correct for the 998, If you have a number in the middle 12g295 or 12g206 then its a performance small bore head from the cooper era.
#5 MiniMoe
MiniMoe
  • 65 posts
Posted 12 September 2010 - 04:14 PM
For Clarity
Thanks Cooper. i appreciatte the response.
