Turbo Fuel Tank
5 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 14 September 2010 - 09:35 PM
Hi guys just got a quick question on the best fuel tank for a turbo I've heard you can use a mpi fuel tank as it's got the return fuel connection in it is this true also do you use the fuel pump that's on the tank or get maby a facet or similar high pressure pump
#2 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 14 September 2010 - 11:40 PM
If your running low boost around 7 PSI I believe you can get away with an SPI tank however any more more that and you need an MPI tank or a separate pump.
#3 Ethel
  • 25,941 posts
Posted 14 September 2010 - 11:43 PM
Either of the injection tanks will do. You need a roller vane pump that will maintain constant pressure, hence the need for a return pipe so the pump runs constantly. The Mpi pump operates at a higher pressure which helps if you are running high boost. I think the SPI pump is good up to about 1 bar of boost, those who have used it will confirm.
#4 John H
John H
  • 768 posts
Posted 15 September 2010 - 08:47 AM
The SPI pump should be able to deliver 1BAR so you should be able to manage 10psi of boost providing the pump is in good order.
MPI pump I think is either 2.5BAR or 3BAR which would allow you over 30psi of boost if you are insane :-
#5 leepol83
leepol83
  • 1,744 posts
Posted 15 September 2010 - 07:34 PM
MPI pump I think is either 2.5BAR or 3BAR which would allow you over 30psi of boost if you are insane :thumbsup:
Ok thanks guys I will get the mpi fuel tank with the pump in it and use that pump.
Next question what size fuel pipe do I need and can I run it in rubber under the car I will need 2 pipes under the car won't I is that correct.
Edited by leepol83, 15 September 2010 - 07:37 PM.
#6 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 16 September 2010 - 08:15 PM
MPI pump I think is either 2.5BAR or 3BAR which would allow you over 30psi of boost if you are insane :)
Pipe size 8mm as opposed to the standard 6mm.
And i would not run rubber under the car as it will deteriorate very quickly exposed. If you going to be using rubber it needs to go through the cab and it has to be one continuous section of pipe there can be no joins in the pipe within the cab.
Edited by Sleepy Stu, 16 September 2010 - 08:16 PM.
