Lucas Automatic Transmission Fix - Stops Slip
11 replies to this topic
#1 ShoutforJoy
ShoutforJoy
  • 738 posts
  • Local Club: TMF+, Automatic Mini Register
Posted 15 September 2010 - 08:10 AM
Came across this product on Ebay: http://cgi.ebay.co.u...em=300460507644
It's a new one on me. Has anyone else come across it? Does it work?
Clearly it's not going to solve problems in an auto box over the long term but, given the high cost of most auto box repairs, it could be a useful short-term solution.
I don't actually need it at the moment - I'm just curious.
#2 LolaAuto
LolaAuto
  • 322 posts
Posted 15 September 2010 - 08:13 AM
mmm Im interested in this to my auto has problems getting into reverse you have to push it in really hard really need to sort that
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 September 2010 - 08:14 AM
No...
Do not put ANY additive in a mini auto box, basically because any product like this is designed to be used in an auto box which is separate from the engine, therefore is designed to be used with ATF and not engine oil. And likewise any engine oil additive will not be designed to be used in a gearbox.
#4 LolaAuto
LolaAuto
  • 322 posts
Posted 15 September 2010 - 08:20 AM
No...
Have you got any idea regarding my auto you have to push it hard to get into reverse but once its in there its fine
any suggestions on what to do ?
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 September 2010 - 09:36 AM
First thought would be an issue with the selector rather than the gearbox, however, best person to talk to regarding Auto's is Martin @ MRA-Minis
#6 ShoutforJoy
ShoutforJoy
  • 738 posts
Posted 15 September 2010 - 03:26 PM
No...
I always thought that too. But this item is listed as being for a Mini. I guess you always have to be careful what you read on Ebay.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 September 2010 - 03:35 PM
Well technically it says MINI which could well imply the BMW MINI....
I'm sorry but anything which stops oil leaks has to do it by bunging up the hole with something, this could mean it has something in it which sets or seals... is this something you want floating about your oil ways ?
#8 Nelson92
Nelson92
  • 325 posts
Posted 15 September 2010 - 05:46 PM
hi
I've discussed this with martin/mra previously but i use slick 50 in my 1275 auto with no ill effects.
I think the extra lubrication is not a great enough effect to change the performance of the box. however it does quieten down the engine a little.
i've also bunged wynns stop leak in before. but i do not think this does anything more then thicken up to oil IMO. (and i changed the oil after 6 months)
#9 ShoutforJoy
ShoutforJoy
  • 738 posts
Posted 16 September 2010 - 04:25 PM
I thought I'd check with the Ebay vendor about his claim that it is for a Mini/MINI. And (surprise, surprise) I got no response! So I emailed the manufacturer and got an interesting response from them:
"The Tfix is not suitable for your mini transmission, you would be better off with the oil stabilizer part number 10001.
That would help if it is the band seals that have worn"
This is the stuff they are referring to: http://www.lucasoil....g...&product=12
hhhmmm...
#10 Nelson92
Nelson92
  • 325 posts
Posted 16 September 2010 - 05:30 PM
hhhmmm...
with an auto look to change the oil every 6 months. i've been doing that for the last 3 years and have had no problems.
because of that you don't want to spend to much on additives as you're chucking the oil so often.(i got my slick free :))
imo you're better off finding a oil that suits your car and changing it more often.
#11 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 17 September 2010 - 07:30 AM
autos last beter if you dont drive them flat out :D and change the oil every 1000-1500 miles and flush ever 3000 with a filter
dave
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 September 2010 - 07:31 AM
would tend to agree...
