When To Seam Sealer
Posted 19 September 2010 - 05:38 PM
cheers, tom.
Posted 19 September 2010 - 05:40 PM
Posted 19 September 2010 - 05:45 PM
Posted 19 September 2010 - 05:49 PM
hope this helps liam
Edited by liam-ds, 19 September 2010 - 05:49 PM.
Posted 19 September 2010 - 06:08 PM
damn, i literally just put the etch on the inner sill repair. will it be ok over that?
doesn't make that much difference what way round you do it as long as you do a good job with the sealer.
Posted 19 September 2010 - 07:38 PM
Posted 19 September 2010 - 07:41 PM
thanks
Posted 20 September 2010 - 03:37 PM
off topic but where do you get seam sealer?
thanks
Brown Bros Group
10 Quorn Way, Northampton NN12PY
01604 624211
http://maps.google.c...119625507523235
Posted 20 September 2010 - 06:41 PM
have always put seam sealer on first. don't forget to mask before you put it on to leave you with a solid edge
Not to hijack the thread but can you explain the reason/need for the 'solid edge'? Thanks
Posted 20 September 2010 - 06:49 PM
Its best to do any sealing after primer, as it is over paintable.
Let it set overnight before trying to paint over it, although you can buy wet on wet sealer that you can paint straight over pretty much although it is more expensive.
Also I wouldnt bother with the red oxide, its an old out-dated method that I've seen cause paint reactions with most modern paints. I would etch prime, sealer, a couple steady coats of stonechip then topcoat and then some waxoyl.
