Radiator Size
4 replies to this topic
#1 teh nub
teh nub
  • 14 posts
Posted 19 September 2010 - 10:48 PM
1971 Austin Mini - 1380 Stage 2 with an 1" 3/4 Hiff Carb built by Jonspeed, 11 blade fan. I believe the car still has the stock radiator as I purchased it about 3 weeks ago.
There are two different size China made aluminum radiators on ebay that i'm looking at.
Larger
Core size: H270mm×W 258mm×T50mm (H10-5/8"×W10-1/8" ×T2")
Overall Size(in) approx: (H14-1/8"× W10-5/8"×3-1/4") H359mm×W270mm×T83mm
Inlet/Outlet: 25mm / 25mm
Rows: 2
Attached File  large.jpg   35.86K   12 downloads
Smaller
Core size: H270mm×W 258mm×T42mm (H10-5/8"×W10-1/8" ×T1-5/8")
Overall Size(in) approx: (H14-1/8"× W10-5/8"×2") H359mm×W270mm×T51mm
Rows: 2
Attached File  small.jpg   46.97K   8 downloads
The smaller one is $50 cheaper, but would it even be worth it in the first place since the core is 3/8" smaller?
Or is the smaller radiator designed for use with the "tropical fan"? (Which I have been thinking about getting to help with cooling)
#2 Wil_h
Wil_h
  • 3,244 posts
Posted 20 September 2010 - 06:48 AM
Personally I'd go fo the bigger one. The smaller one might be ok, but no-one on here will(should) take the responsibility of advising it'll be ok.
#3 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
  • Local Club: Lone Ranger
Posted 20 September 2010 - 05:19 PM
i've got the 42mm one and its very efficient. :D
the standard minispares 2-core rad is 42mm, and i believe all 3-core are aswell. although i did buy a cheap get you home 2-core from a show and it was only 25mm :thumbsup:
#4 teh nub
teh nub
  • 14 posts
Posted 20 September 2010 - 11:05 PM
Does anyone know the thickness of the 4 core radiator? I didn't see it listed minispares website.
#5 mike.
mike.
  • 6,176 posts
Posted 21 September 2010 - 12:36 AM
That 42mm ones looks the same as one i've recently got from china. Much more like the right size when compared to a standard rad, and is more similar in design.
I'd go for the 42mm.
