Model: Rover Mini Sprite 1275
Year: 1992
It seems that my headlight steams or smokes from time to time, has anyone else noticed this? It's usually very slight/vague mist.
What could be causing this?
Osf Headlamp Steam?
Kaison
, Sep 20 2010 07:11 PM
4 replies to this topic
Posted 20 September 2010 - 07:11 PM
Posted 20 September 2010 - 07:40 PM
It's usually condensation or dampness evaporating off as the light heats upModel: Rover Mini Sprite 1275
Year: 1992
Posted 20 September 2010 - 07:42 PM
I vaguely remeber my halogens doing it when it is raining.
Posted 20 September 2010 - 07:43 PM
Usually? I've seen it happen after long drives on days or weeks without rain or going through puddles
Posted 20 September 2010 - 07:57 PM
Depends exactly where the mist is coming from, but could well be a sign of a build up of rain soaked dirt & debris behind the headlamp bowl. The steam/mist being the rain water evaporating due to the heat generated by the headlamp. Doesn't tend to happen to the near side so much, as kerbside puddles tend to wash the dirt away more effectively. If I were you, then I would get the off side front wheel off and get your hand up behind there to find out. If it is a build up road dirt you need to get it out as soon as possible, so that it doesn't rot your off side wing out over the winter. I have the same model on a 93 plate and recently fitted wing liner/splash guards to stop exactly that happening.
