My Mini Now Leaks Oil Also Subframe Moves
8 replies to this topic
#1 josh.evans
josh.evans
  • 1,439 posts
Posted 21 September 2010 - 05:01 PM
hi my mini was hit on friday night and caused damaged i decided to look at it today i pushed it out of the garages and there was this scraping noise coming from the left front wheel when i turn the steering wheel also i noticed there was about a inch circle on the floor of oil could this be due to me driving it with out an exhaust on? as it never leaked before also i opened the bonnet to see what the noise was and when you turn the steering wheels the subframe moves side to side why is this can it be fixed?
josh
#2 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 21 September 2010 - 05:14 PM
hiya mine does the engine movement when you turn you can see the egine move side to side i asked local mini garage he said it fine it because the subframe is on rubber monts hope this helps danny
#3 josh.evans
josh.evans
  • 1,439 posts
Posted 21 September 2010 - 06:37 PM
right but it never done it before?
#4 josh.evans
josh.evans
  • 1,439 posts
Posted 21 September 2010 - 07:18 PM
can anyone else help like with the leaks and the subframe moves like loads ????? surely thats not right?
josh
#5 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 21 September 2010 - 07:43 PM
are all the subframe bolts tight? subframe mounts good condition? might be worth checking and tightening all the bolts. as for the oil leak cant say unless i look at it, might be able to pop over again soon and take a look?
#6 samsfern
samsfern
  • 5,243 posts
Posted 21 September 2010 - 07:46 PM
my front subbie moved, i solid mounted the front subframe to stop that, made the steering feel so much more direct and responsive, and feels so much better in corners.
#7 josh.evans
josh.evans
  • 1,439 posts
Posted 21 September 2010 - 07:57 PM
right ok i will try and tighten them as for the oil leak it is tiny amount im thinking thats something happen because i drove around 5 miles with no exhaust just the lcb i dont know?
josh
#8 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 21 September 2010 - 07:59 PM
i dont think having the exhaust off would cause an oil leak, unless u can actually feel oil coming out the y piece of the exhaust?
#9 josh.evans
josh.evans
  • 1,439 posts
Posted 21 September 2010 - 08:05 PM
i just dont know because it didnt do it before that and it ran like a bag of ****. would the loss of pressure change anything i dunno lol
josh
