Rebuilding My 85 Mayfair
No replies to this topic
#1 minimad666
minimad666
    Starting My Mini Up
  • 1 posts
Posted 21 September 2010 - 05:11 PM
I've had my mini since 2003 and when I went to uni I decided to completely strip it down and rebuild it and replace everything that either needed replacing or because I wanted to upgrade. Being away at uni meant I could only work on it when I was home and when finances weren't too stretched.[/size]
Here's what I started with....
Attached File  DSCN0532.JPG   2.32MB   10 downloads
In the picture I had already removed most of the windows and the car had a flip-front so was just put to one side.
Attached File  DSCN2813.JPG   2.3MB   8 downloads
Everything stripped and removed, and all welding and replacing of rusted panels done, both inner and outer sills, o/s inner wing, rear valance and both windscreen corner and closing panels.
Attached File  n514593023_1223254_2671.jpg   67.31K   6 downloads
Must have been involved in an accident and repaired long before I got it judging by this panel.
Now the respray, metallic silver roof.
Attached File  n514593023_1155089_2954.jpg   44.37K   9 downloads
Attached File  n514593023_1188274_2669.jpg   46.1K   8 downloads
New steel front
Attached File  n514593023_1205309_8050.jpg   43.12K   8 downloads
Attached File  n514593023_1230136_3408.jpg   23.63K   7 downloads
Sprayed black, with a slight red and pearl flake in the lacquer.
Attached File  n514593023_1297622_645.jpg   74.71K   8 downloads
Attached File  n514593023_1392070_5534.jpg   74.64K   17 downloads
Ive had leather door cards made for me by a mate in the upholstery department at LandRover
Attached File  2634_57621443023_514593023_1471192_624554_n.jpg   25.68K   10 downloads
Attached File  n514593023_1317558_8230.jpg   33.52K   11 downloads
The dash was also covered in leather and the clock binnacles sprayed piano black.
Replaced the normal switches with zinc push button swtiches, which were a nightmare to fit because resistors were needed on each LED.
Attached File  switches.jpg   61.81K   10 downloads
Its almost finished now, most things have been replaced.
1380 engine, 276 cam, stage 5 full race head, iskey valve springs, titanium valves and seats, large aluminium rad, new gearbox with 3.7 diff,
reground crank, metro turbo clutch, HIF44, Aldon yellow dizzy with aldon electronic ignition, electric fan from MG ZR, silicone hoses,
cooper S crank pulley and damper, 1.5 fixed negative camber all round, adjustable tie-bars, Hi-los, KAD quickshift, new wiper motor and wheel boxes,
all new brake lines, new wiring loom and leather roof lining, playmini stainless large bore side exit, crystal halogen head light conversion and jewel clear rear lights.
Attached File  almost_finished.jpg   77.34K   16 downloads
