After having trouble getting it started i had a look and found there was no spark. After changing distributor and coil i discovered the solenoid was not working.
I did this by bridging straight from the loom to the coil, bypassing the solenoid.
This made it start (big success) This then uncovered other issues involving the engine not ticking over but that problem is in another post. However whilst in my search for the reason it wouldn't tick over it then stopped running all together (fail) possibly due to bridging the solenoid. I have now changed the solenoid eliminating the need for the bridge but now when i turn the key it just clicks and does nothing else. I think this is a starter motor problem??? but do not know and would like some expert advice before i go shelling out for a new starter motor.
Edited by chippy2710, 21 September 2010 - 07:30 PM.
