Odd ? - Vin Number?
Posted 22 September 2010 - 12:00 AM
First let me start by saying I'm NOT ASKING for one!
Okay, there. That done, my Mini's been re-vinned when it was brought over. Due to my over-curiosity, I've been looking for the real VIN for the Mini for a while now.
Since I have my head off - the engine's head, I mean - I've been searching the firewall for any stamped numbers, and realized..
I don't know what I'm looking for.
What is the format of the VIN? 10 numbers? 3 numbers followed by a letter, etc?
On top of that, any other places I should look? (On the bonnet side of the driver's wheelwell I have screw-holes where one should be.)
Cheers,
Mike.
Posted 22 September 2010 - 05:02 AM
They did stamp the VIN number on the scuttle panel in the recess where the bonnet sits
Posted 22 September 2010 - 05:15 AM
Your car is a '92 British Open Classic, however, in one of your posts you suggest that it's an injection ?? This being the case then it's unlikely to be a UK spec car, as the UK spec was carb, which means it's more likely to be of continental origin and therefore originally LHD.
On the other hand it could be a bitza, bits of this and bits of that.
Posted 22 September 2010 - 06:12 AM
Posted 22 September 2010 - 06:52 AM
There is only one place to look for the stamped VIN. In the gutter of the scuttle panel ahead of the RHD driver's seat. Since VINs were introduced in 1980 they have always been there. Prior to that shells were marked with various numbers in different places, but these numbers are not VINs. If the car has had the scuttle repaired or replaced, as is common, it may not have been restamped with it's original VIN. Hence why a new VIN was issued at import. Without the stamping or the original plate (which would have been removed of the stamping couldn't be found on inspection) or some documents, there is no way to know what it originally was. It would be 13 characters and begin SAXX. There is a chance that Heritage might know from the engine number, if that is original. They don't have great records for '80s and '90s cars though.
Posted 22 September 2010 - 09:40 AM
Posted 22 September 2010 - 01:29 PM
I DO know for sure that:
1. Build date was '92, due to finding some date tags on wiring harnesses and other stamped date codes on parts.
2. It IS injection (I took the manifold off, and while I may not be as smarts as most folks here, I can tell the difference between carb and injection.
3. It was originally built LHD, not converted over as I had originally thought.
4. Engine's original to the car, and the number I have for it is proper for the car.
While it's not live or die if I don't find the original number, curiosity has always been my downfall.
I asked about the locations because on newer cars, they put that number just about everywhere, and had hoped that there would be some stampings or plates on the Mini that the previous owner missed.
Edited by coyttl, 22 September 2010 - 01:34 PM.
Posted 22 September 2010 - 03:25 PM
Heritage should be able to trace a VIN number with an engine number if their records allow them to. You should get in touch with them
Posted 22 September 2010 - 03:46 PM
I'll buzz them and see what they say, thanks!The scuttle would be the only place, your car might not have been made in 1992 depends what month the harness and stuff were made it could be an early 1993.
--Mike.
Posted 26 October 2010 - 04:44 PM
Could you give me an idea on how to go about finding it...where do i look?
