Welding
8 replies to this topic
#1 firstforward
firstforward
  • 824 posts
Posted 23 September 2010 - 09:58 AM
I do not know much about welding metals, so can you weld stainless steel and can that be welded to mild steel or any other metal.
#2 Ethel
  • 26,058 posts
Posted 23 September 2010 - 11:11 AM
Yes, but there are different grades & blends. The chances are it will weld well enough with ordinary mild steel wire. It might be worth approaching a professional welder if it's something critical. Cast iron & non ferrous (obviously) don't weld with mild steel kit.
#3 joe90gt
joe90gt
  • 288 posts
Posted 23 September 2010 - 12:18 PM
I've welded ss to mild and was surprised how well it went! - so I presume you can!
#4 kez_19
kez_19
  • 946 posts
Posted 23 September 2010 - 05:06 PM
yes you can but if you don't use stainless steel wire then the weld and eventually the stainless steel itself will rust but it is perfectly easy to do
michael
#5 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 23 September 2010 - 05:18 PM
there was a bloke in one of the mini mags a few years ago that used the double draining boards from stainless steel sinks to make himself a new rust proof floor for his mini!
#6 jimnali
jimnali
  • 260 posts
Posted 24 September 2010 - 04:54 PM
I like it!! Did he use heritage or pattern sinks??
#7 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 24 September 2010 - 05:00 PM
i think he used heritage, scoured (no pun intended) all the car boot sales for them sinks lol he even made an engine breather from 2 stainless steel egg cups welded together and holes drilled, with a clean (no soap) brillo pad in the middle! he was abit of a "that doesn't work as well as id like, ill make a better 1" kinda guy, fairly old to, in his late 60s if i recall correct!
#8 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 26 September 2010 - 08:22 PM
If that works, does sort of make you wonder why no one makes a stainless full floor pan?
Then again, they'd do themselves out of business in the long run.
#9 mini.cooper998
mini.cooper998
  • 685 posts
  • Local Club: looking
Posted 27 September 2010 - 10:24 AM
if you do it with Arc welding you can use Diff Rods they are designed to do both types of metal
