Steering Wheel Keeps Changing Straight On Position
Posted 23 September 2010 - 03:53 PM
when I go in a straight line, the wheel is showing straight... but then if I go round a steep corner, it will then be off center... i.e. turned slightly down to the right if ive gone round a right hand bend...
any ideas?
thanks
J
Posted 23 September 2010 - 03:57 PM
But get it fixed PRONTO!
Posted 23 September 2010 - 03:59 PM
Posted 23 September 2010 - 05:42 PM
Posted 23 September 2010 - 10:56 PM
Call up if you want me to check it but sounds like something is loose.
Posted 24 September 2010 - 11:38 AM
Posted 24 September 2010 - 11:42 AM
Is it the 2 bolts under the carpet on the passenger side footwell?
Jason
Posted 24 September 2010 - 12:13 PM
two nuts on the drivers side adjacent to where the steering column attaches to the rack...
Posted 24 September 2010 - 12:22 PM
Thanks for the replies!
Jason
I doubt it's the U bolts as you'd probably notice that in weird handling, too. Also the rack can't slip very far even with loose U bolts as the stud is still in the chassis hole and only has that much play. I guess it's the column slipping over the splines instead, either because of a loose or missing bolt.
Posted 24 September 2010 - 01:13 PM
Hi Gulfclubby,
This certainly CAN be caused by rack slipping through the U bolts, but yes, can be felt as weird handling... On picking up my new car 2 weeks ago, the straight ahead position swapped from 10 o clock to 2 o clock in one corner. Not fun when entering a slip road to the motorway from a roundabout...
I stopped at the next services, tightened the U bolts and all is fine !
Edited by L400RAS, 24 September 2010 - 01:14 PM.
Posted 24 September 2010 - 04:37 PM
have only had a short drive in it down the road... but feels like it's sorted it out for me!
thanks all.
will let you know on a longer run if its not fixed the problem!
thanks
J
Posted 26 September 2010 - 07:45 AM
thanks all
J
