How Much Oil Is "normal" For A Mini To Use, And Whats The Best Stuff?
Posted 24 September 2010 - 02:24 PM
also, what would be the best oil to use?
manufactures recomendation is 10w40 but a few people have mentioned 20w50? and if so what brand?
Posted 24 September 2010 - 02:38 PM
Ben
Posted 24 September 2010 - 02:44 PM
Posted 24 September 2010 - 02:45 PM
Posted 24 September 2010 - 02:47 PM
ok thanks, mine seems to be using a hell of a lot of oil then! there are no leaks when the engine is off, and its not burning it, my only thought is i that it may be being forced out with oil pressure when its running, but i cant seem to find where, ill keep an eye on it!I use 10/40 in my 2000 mpi & i change it every 6000 miles & very rarely have to top it up in between
cheers guys
Posted 24 September 2010 - 02:51 PM
cheers guys
If its leaking from somewhere while driving you should still be able to see traces under the car on the floor or in the engine bay.
Posted 24 September 2010 - 02:55 PM
cheers guys
thats what i would have thought, but from what i can see on the garage floor, theres nothing, the front of the block is quite dirty and oily, ill give it a really good clean up and then see if i can spot where it is coming from
Posted 24 September 2010 - 03:59 PM
Posted 24 September 2010 - 04:40 PM
Posted 24 September 2010 - 06:24 PM
It may also be worth hooking the car up to a gas analyser to see what the emissions are like an if there's any evidence of the oil that way...
There's not many places oil can disappear to... it's usually on the floor or out the exhaust pipe.
Posted 24 September 2010 - 11:31 PM
Obviously, oils have improved since then and so has the degree of precision in engine manufacture/rebuild. I would say that anything worse than 250 miles per pint on any A series engine is a good indication of the need for a major overhaul.
Posted 25 September 2010 - 01:20 AM
